  2. Redmine
  3. Redmine Theme Update Problem.
Scheduled Pinned Locked Moved Redmine
8 Posts 3 Posters 3.6k Views 3 Watching
  • N Offline
    N Offline
    Neluser
    Hello,
    I have encountered a problem while updating the theme for Redmine 6.
    The issue is that I am unable to follow the instructions for updating the theme.
    I am using the Boostmine 1.6 theme. However, due to major changes in Redmine 6, the theme does not work correctly in some areas (icons are missing in certain places).
    The developer's website provides a guide for fixing this issue:
    https://bestredminetheme.com/kb/installing-the-theme-in-your-redmine-application/#
    Unfortunately, when I enter the command, I get an error.
    Is there any way to bypass or fix this issue?
    Thank you.
    • BrutalBirdieB Offline
      Did you try the documented steps?
      https://docs.cloudron.io/apps/redmine/#installing-themes
      N 1 Reply Last reply
      • J Online
        J Online
        Just a guess, it seems maybe your app is in recovery mode? Since it says database.yml not found which is generated on app start up.
        If so, run /app/pkg/start.sh . This generates the config file. After that, try the plugin installation commands.
          N Offline
          N Offline
          Neluser
          @joseph
          You were right—the app was indeed in recovery mode. However, even in the normal mode, I am still getting an error.
          root@f8330007-5d00-40cb-b467-b37e622b130d:/app/code# bundle exec rake redmine:plugins NAME=redmine_checklists RAILS_ENV=production
          rake aborted!
          ArgumentError: Missing `secret_key_base` for 'production' environment, set this string with `bin/rails credentials:edit` (ArgumentError)
                    raise ArgumentError, "Missing `secret_key_base` for '#{Rails.env}' environment, set this string with `bin/rails credentials:edit`"
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application/configuration.rb:519:in `secret_key_base='
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application/configuration.rb:503:in `secret_key_base'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:470:in `secret_key_base'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:205:in `block in message_verifiers'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/message_verifiers.rb:132:in `build'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/messages/rotation_coordinator.rb:85:in `block in build_with_rotations'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/messages/rotation_coordinator.rb:85:in `map'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/messages/rotation_coordinator.rb:85:in `build_with_rotations'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/messages/rotation_coordinator.rb:19:in `[]'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:232:in `message_verifier'
          /run/redmine/vendor/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/railtie.rb:355:in `block (3 levels) in <class:Railtie>'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:97:in `class_eval'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:97:in `block in execute_hook'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:87:in `with_execution_control'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:92:in `execute_hook'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:62:in `block in on_load'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:61:in `each'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:61:in `on_load'
          /run/redmine/vendor/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/railtie.rb:354:in `block (2 levels) in <class:Railtie>'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:94:in `block in execute_hook'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:78:in `block in run_load_hooks'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:77:in `each'
          /run/redmine/vendor/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:77:in `run_load_hooks'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application/finisher.rb:94:in `block in <module:Finisher>'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:32:in `instance_exec'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:32:in `run'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:61:in `block in run_initializers'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:60:in `run_initializers'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:435:in `initialize!'
          /app/code/config/environment.rb:16:in `<top (required)>'
          /run/redmine/vendor/ruby/3.3.0/gems/zeitwerk-2.7.1/lib/zeitwerk/core_ext/kernel.rb:34:in `require'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:411:in `require_environment!'
          /run/redmine/vendor/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:559:in `block in run_tasks_blocks'
          /app/code/lib/tasks/redmine.rake:73:in `block (2 levels) in <top (required)>'
          /run/redmine/vendor/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
          /home/cloudron/rbenv/versions/3.3.4/bin/bundle:25:in `load'
          /home/cloudron/rbenv/versions/3.3.4/bin/bundle:25:in `<main>'
          Tasks: TOP => redmine:plugins:migrate => environment
          (See full trace by running task with --trace)
          • BrutalBirdieB BrutalBirdie
            N Offline
            N Offline
            Neluser
            @BrutalBirdie
            Hello.
            Yes, but I was getting errors there as well.
              Did you read and followed what @joseph wrote?
                N Offline
                N Offline
                Neluser
                @Brutal Birdie
                Yes, but I still get errors, even on a freshly installed Redmine.
                I just tried to contact the Agile developer — hopefully, this will help improve the situation.
                • N Neluser referenced this topic on
                • J Online
                  J Online
                  @Neluser put the app in recovery mode. run /app/pkg/start.sh once. press ctrl+c to stop the app. then run the bundle exec command . this is because the app packaging configures things on start up
                  Can you try with gosu cloudron bundle exec ... ?
