  3. Pi Hole - network-wide ad blocking
59 Posts 19 Posters 38.3k Views 20 Watching
    #21
    Currently, what is holding back pi-hole is a couple of Cloudron limitations:
    • Cloudron reserves port 53 (dns) on the server. Have to fix unbound to listen only on internal interfaces (we listen on 0.0.0.0 and rely on firewall and access control policies to block requests).
    • Some IP based firewall as @savity has been requesting in another thread. This is required to block requests to pi-hole to just your machines/network.
    imc67I 1 Reply Last reply
      imc67I
      imc67I
      imc67
      @girish you don't have these issues if you combine with Wireguard.
        @imc67 indeed. If we bundle them together, it's not a problem. Is this the "preferred" way to package pi-hole?
        MallewaxM imc67I 2 Replies Last reply
        • S
          S
          savity
          wrote on last edited by savity
          #24
          yeah i mean it would be for me 🙂 i would never create pihole acessable for others its for private reasons vpn+pihole. So pihole would be listening, lets say on 10.9.0.0
          Maybe in the future the idea could to configure other apps only availaie in the same VPN Network
            MallewaxM
            MallewaxM
            Mallewax
            @girish @imc67 Same here, I think the combination is awesome and makes a lot of sense. PLEASE, PLEASE...Yes...:-)
            S 1 Reply Last reply
            • MallewaxM Mallewax
              S
              S
              savity
              @Mallewax i think this would lead also to new people using cloudron 🙂
              MallewaxM 1 Reply Last reply
              • S savity
                MallewaxM
                MallewaxM
                Mallewax
                @savity couldn’t agree more. For me it would be a killer feature. And would make for a nice campaign on Twitter, Reddit et. all. Just look how many people google this and try to establish it manually....this is a mainstream feature, that would be appreciated by the entire user base, much more than specific applications that appeal only to certain users.... my opinion
                  imc67I
                  imc67I
                  imc67
                  @girish definately! 🙂
                  • marcusquinnM
                    marcusquinnM
                    CA Maintainer Super Fan
                    Haha, Pie Hole / Cake Hole is British for your mouth, as in; shut your pie hole 😮
                    https://www.urbandictionary.com/define.php?term=Pie Hole
                    ? 1 Reply Last reply
                    • marcusquinnM marcusquinn
                      A Former User
                      @marcusquinn
                      Pi-hole, not Pie hole
                      • ? A Former User
                        @marcusquinn
                        marcusquinnM
                        marcusquinnM
                        @Hillside502 3.14159265359... hole 🙂
                          A Former User
                          How is the progress here?
                          • ? A Former User
                            S
                            S
                            savity
                            @timbo Yeah any information this ?
                              Last I checked it was quite tricky to deploy pi-hole with docker. Does anyone have experience with this style of deployment? It was really made like a "distribution"/"OS" instead of a separate app.
                              iamthefijI 1 Reply Last reply
                                iamthefijI
                                iamthefijI
                                iamthefij
                                @girish It's pretty straightforward as far as I can tell. I've got two instances hosted via Docker on Raspberry Pis at my home.
                                I agree with folks above suggesting though that it'd be best to expose only to internal services and likely inside a VPN. There is probably a decent way to do this in a single app, but I wonder if there is value in creating a new way to expose particular Apps to other apps via a shared network.
                                This would allow exposing a Pi-Hole app that has no "public" ports to any VPN app (OpenVPN, Wireguard, etc) with an internal hostname (app name?).
                                  @iamthefij So, let's say the VPN app had a way to set a custom name server and one could just edit some file and set it to the pi-hole app, would this be good enough already? Given that the OpenVPN app is custom anyway, we can even add a simple UI that allows a user to set the DNS server IP (as you say, this might be the internal host name since IP might be dynamic actually).
                                  This seems quite doable.
                                  • doodlemania2D
                                    doodlemania2D
                                    doodlemania2
                                    I've got one up and running on a public endpoint, no sweat. I just set the server to only allow queries from my IP range, deny all by default.
                                      iamthefijI
                                      iamthefijI
                                      iamthefij
                                      @girish yea, that's pretty much all that should be required. As long as the two containers can communicate via their internal host names, it should be sufficient.
                                      The other advantage here is that it enables you to use the DNS from a mobile phone. Otherwise whenever you switch to a new network you receive the networks DNS via DHCP.
                                      • doodlemania2D doodlemania2
                                        iamthefijI
                                        iamthefijI
                                        iamthefij
                                        @doodlemania2 I'm not sure exactly what you've configured, but many folks do not have static IP addresses to do this with. Not only does my home network frequently change IP addresses, but my mobile network does as well.
                                        • imc67I
                                          imc67I
                                          imc67
                                          @Mallewax said in AdGuard - Network-wide ads & trackers blocking DNS server:
                                          Pihole plus Wireguard
                                          Let's vote more here: https://forum.cloudron.io/topic/1355/pi-hole-network-wide-ad-blocking
                                          In short why:
                                          WireGuard is a very fast, safe and stateless VPN, great with mobile apps to be ALWAYS CONNECTED via your own VPN & covered by the Pi-hole adfilter & security platform. Faster (mobile) connections (no more ads and bulky stuff) to your own safe VPN (no more sniffing by mobile providers or obscure VPN providers).
                                          Need to say more 😉
