  3. Pi Hole - network-wide ad blocking
59 Posts 19 Posters 37.4k Views 20 Watching
  • iamthefijI iamthefij
    @girish yea, that's pretty much all that should be required. As long as the two containers can communicate via their internal host names, it should be sufficient.
    The other advantage here is that it enables you to use the DNS from a mobile phone. Otherwise whenever you switch to a new network you receive the networks DNS via DHCP.
    @iamthefij For OpenVPN, I started a new thread - https://forum.cloudron.io/topic/3139/openvpn-admin-ui
    • iamthefijI
      iamthefijI
      iamthefij
      Cool! Do apps already have access to each other through the bridge? Or would that need to be made possible as well?
      yusfY 1 Reply Last reply
        While there is network connectivity between the apps (docker's icc is true), the apps do not know the internal IPs and thus cannot easily discover each other. We have to come up with some sort of standard hostname naming mechanism to allow easy configurability.
          yusfY
          yusfY
          yusf
          wrote on last edited by yusf
          #44
          Being able to host Cloudron behind Wireguard in a way where apps would only be accessed through WG would be a nice feature for security-demanding deployments.
          Edit: Sorry, wrong thread.
          • S
            S
            savity
            Are there any news Regarding Wireguard and Pihole in Cloudron?
            • imc67I imc67
              Pi-Hole on Cloudron is useless IMHO for only internal "filtering".
              Only in combination with a VPN like WireGuard it's a perfect combination to be online, outside of your 'safe home wifi', without sniffing of mobile providers proxies and "free open wifi", and with a kind of safetynet by Pi-Hole.
              @luckow yes I do have a RaspberryPi with Wireguard AND Pi-Hole at home, but as an extra "external" backup its very welcome (and very easy) to have Pi-Hole+WireGuard in a Cloudron app. 😉
              murgeroM
              murgeroM
              murgero
              @imc67 said in Pi Hole - network-wide ad blocking:
              This is a common misconception - Just because you are using a VPN does not mean you are completely safe. Sure you maybe safe from traffic sniffers at your local mcdonalds or starbucks, but a VPN that is tied to your name and a device that has other software on it like facebook, twitter, etc still makes you vulnerable to data leakage, tracking and more.
              https://urgero.org
              • murgeroM murgero
                marcusquinnM
                marcusquinnM
                @murgero Exactly that! There's a reason why not one single bank in the world has "Login with Google/Facebook/Twitter" etc.
                • S savity
                  #48
                  @savity I did give pi-hole a try but it was really hard to package from source easily. I managed to instead package the new kid in the block - AdGuard. Some reviews here https://home-assistant-guide.com/2020/09/26/adguard-home-vs-pi-hole-2020-two-ad-and-internet-tracker-blockers-compared/ and https://mariushosting.com/synology-adguard-vs-pi-hole/ . It requires some support from the platform, depending on time we might add it to Cloudron 6 (or the release after). https://forum.cloudron.io/topic/3075/adguard-network-wide-ads-trackers-blocking-dns-server is the forum topic for that.
                  S murgeroM 2 Replies Last reply
                    S
                    S
                    savity
                    @girish Sad to hear thath Pi-hole didn't workout but lets see how AdGuard is 😉 Thanks for your Work
                      murgeroM
                      murgeroM
                      murgero
                      @girish I have adguard installed via homeassistant on a RPi4 and it works just as pi-hole does. Admin UI looks similar as well. I'd suspect you will find little to no complaints on packaging adg or pih.
                      https://urgero.org
                      • murgeroM murgero
                        @murgero Yes, it also seems adh has some important features like DoH.
                        varunsridharanV 1 Reply Last reply
                          Adguard Home will be available in Cloudron 6 - https://forum.cloudron.io/topic/3075/adguard-network-wide-ads-trackers-blocking-dns-server . It is similar to pi hole (and more feature rich).
                            varunsridharanV
                            varunsridharanV
                            varunsridharan
                            @girish i would love to see PI-Hole in Cloudron.
                            And option to setup Pihole with Android Private DNS which requires DNS-over-TLS
                            and i wrote a quick setup script for Pihole DNS-over-TLS
                            https://github.com/varunsridharan/pi-hole-android-private-dns/blob/main/pi-hole5.sh
                              I have added an option to make the DNS server of the OpenVPN app configuration - https://forum.cloudron.io/topic/3875/adding-custom-dns-server . So, you can install AdGuard Home and OpenVPN and then make OpenVPN use AdGuard as the DNS server.
                                Just leaving a note here for people looking into pi-hole. Starting 6.2, Cloudron also supports DoT (DNS over TLS) in AdGuard Home. This makes it work out of the box in Android phones.
                                  @girish so if I've got this right, I could AdGuard to stop any ads ever being shown on the Android tablet my kids use? (most are blocked already either using uBlock Origin in the browsers or e.g. NewPipe instead of YouTube - although I can't uninstall YT on this machine and no doubt the kids will find and open it at some point)
                                  Could I somehow achieve that using a Cloudron installed on a VPS, or is AdGuard something I'd need running on a machine at home? Thanks!
                                    necrevistonnezrN
                                    necrevistonnezrN
                                    @jdaviescoates
                                    yes, you can do that (mind you that you can filter ads based on domains etc - there are sneaky ads that you can’t catch with a DNS filter (e.g. if they come from the same domain as the content, etc). But it helps a lot.
                                    IMHO it’s easier though to just get a dedicated Raspberry Pi, put www.dietpi.com on it, and you should be good to go with Pi-Hole, Unbound, and encrypted DNS in minutes. It has A LOT of other apps as well including AdGuard Home (and many you won’t even find on Cloudron such as Wireguard, Home Assistant, Pydio, Plex, etc.) - though not dockerized - but I like to have this dedicated little device kept simple and not facing the internet.Just servicing the local network with some services.
                                      @jdaviescoates
                                      @necrevistonnezr thanks, so just be clear it sounds like I would need a machine at home to take advantage of this stuff, right?
                                      Or is it somehow possible to use a VPS too?
                                      Thanks!
                                        Thanks!
                                        necrevistonnezrN
                                        necrevistonnezrN
                                        @jdaviescoates yes, a „machine“ 🙂 at home (well, it’s just a tiny box)
