  2. Postiz
  3. Issue with uploading images
Scheduled Pinned Locked Moved Postiz
18 Posts 7 Posters 4.8k Views 7 Watching
  • T Offline
    T Offline
    TheMoodBoardz
    Hi, I seem to be having issues with my install of Postiz, when creating a post it appear that it does not display a preview of the image uploaded to the post nor does it attach the image to the post as every platform returns 404
    • BrutalBirdieB Offline
      Thanks for the report. I could reproduce this.
      Web Terminal:
      Mar 30 01:56:03 ⨯ upstream image response failed for https://postiz.cloudron.dev/uploads/2025/03/30/49382b221aa01017ca410af12b0ed4d84.jpeg 404
      Browser Network Logs as HAR:
      https://paste.cloudron.io/yepamidelo.json
      The file in question exists on the system tho:
      root@c9f0d043-77ae-437c-af76-61fac038ff04:/app/code# ls -lah /app/data/data/2025/03/30/
      total 560K
      drwxr-xr-x 2 cloudron cloudron 4.0K Mar 30 00:54 .
      drwxr-xr-x 3 cloudron cloudron 4.0K Mar 30 00:54 ..
      -rw-r--r-- 1 cloudron cloudron 4.2K Mar 30 00:54 49382b221aa01017ca410af12b0ed4d84.jpeg
      -rw-r--r-- 1 cloudron cloudron 541K Mar 30 00:54 9efd2873af79aa2b26100a788471cbd86.jpg
      There is a similar issue here: https://github.com/gitroomhq/postiz-app/issues/380
        @staff
        In app debug mode.
        For some reason and do not ask me why.
        When using /uploads for https://git.cloudron.io/packages/postiz-app/-/blob/master/start.sh?ref_type=heads#L71 and https://git.cloudron.io/packages/postiz-app/-/blob/master/start.sh?ref_type=heads#L73 and creating /uploads and giving perms chown -R cloudron:cloudron /uploads.
        This just works. 🤔
        Sooooo 🤷
        Let's just create /uploads as symlink to /app/data/data 😬
        This feels wrong... but works, I tested it.
        PS: Youtube posting is bricked it seems. But that is from the app it self.
        [Error] posting on youtube TypeError: Cannot read properties of undefined (reading 'releaseURL')
        • BrutalBirdieB BrutalBirdie referenced this topic on
          Found a real fix. App will be updated.
          • nebulonN Away
            nebulonN Away
            Should be fixed with latest released package version. Thanks @BrutalBirdie , good find!
            Hopefully the upstream change will be accepted https://github.com/gitroomhq/postiz-app/issues/712
            • andreasduerenA Offline
              andreasdueren
              Oh I think this is why I can't seem to get uploads to R2 working, because this is hardcoded now?
              • T Offline
                T Offline
                tetr
                I'm running into this exact issue again. Perhaps the app updates led to the patch to break it now?
                • S Offline
                  S Offline
                  shrey
                  wrote on last edited by shrey
                  I'm running into the same issue, in the latest version.
                  From my .env ->
                  # Where will social media icons be saved - local or cloudflare.
                  STORAGE_PROVIDER="local"
                  # Your upload directory path if you host your files locally, otherwise Cloudflare will be used.
                  UPLOAD_DIRECTORY="/app/data/data/"
                  Browser error:
                  "url" parameter is valid but upstream response is invalid
                  Server error:
                  ⨯ upstream image response failed for https://my-postiz-domain/uploads/2025/07/23/a716efeb832223bc97d8e5a9c3b010ceb.jpeg 404
                    I will try to reproduce this.
                      Ah, it seems this issue is still the same.
                      @BrutalBirdie solution was not yet accepted upstream and the Cloudron package does not include @BrutalBirdie fix.
                      Thus, the image display 404 issue persists.
                      @BrutalBirdie maybe you can bump your PR on GitHub and Cloudron will add this overwrite for now.
                        It seems someone from here also opened a GitHub issue https://github.com/gitroomhq/postiz-app/issues/886 and linked this topic 😄
                        Since this is hosting specific the issue is somewhat displaced there.
                        Yes it is an issue, but it is specific to the hosting method, in this case Cloudron.
                        It is not "a postiz issue" but I have created a PR to make postiz more flexible for everyone self-hosting.
                          Oh wait, your PR is included in the Cloudron package @BrutalBirdie
                          I will have to look into it why it is broken now, again.
                            Nah, I look into it.
                            I already handled postiz and I might be faster figuring it out again.
                              Found the issue, fixed it, pipelines are running.
                              App update coming soonTM.
                                @shrey can you confirm this is now working as expected?
                                I've installed the latest version from the Cloudron app-store and found no more issues with image uploads.
                                S 1 Reply Last reply
                                  S Offline
                                  S Offline
                                  shrey
                                  @james Hi. Well, I've tried only with Instagram (Standalone) currently, and that is currently not working due to some other upstream related issue.
                                  Although, wasn't able to complete the full (images related) pipeline, i was able to upload and preview the images within Postiz at least, which worked fine.
                                    fyi: @postiz users
                                    We are aware now this problem is back.
                                    I am currently working on a fix.
                                      andreasdueren
                                      Hey @brutalbirdie is there a specific reason why
                                      is set in the start.sh? I'd like to test this with Cloudflare R2
