  3. Email sending issue again (Was: URGENT)
email
28 Posts 7 Posters 9.3k Views 7 Watching
    @mmtrade once upstream merges, we will make a new mail container image that should fix the problem. I think haraka maintainers are in US timezone..
    • M
      mmtrade
      @girish @joseph @nebulon this issue is still here
      maybe what you sent was not worked on
      the buy is very bad and nothing is working on this cloudrron
      d19dotcaD 1 Reply Last reply
      • M mmtrade
        d19dotcaD
        d19dotcaD
        d19dotca
        @mmtrade The fix was just merged less than 8 hours ago by the Haraka maintainers (outside of Cloudron's control). Give everyone a reasonable amount of time, and I'm sure it will be ready soon.
        Dustin Dauncey
        www.d19.ca
          I have made a new build of mail container.
          IMPORTANT: Do not apply this fix unless you are affected by this . The new mail container passes tests but it also contains a new Haraka release.
          • Edit /home/yellowtent/box/src/infra_version.js . Change the mail container image to registry.docker.com/cloudron/mail:3.16.1@sha256:900b7f55a74a289568c501cd873c24738d424e24f005c3c49cf76a26c296ec22
          • systemctl restart box
          • M
            mmtrade
            @girish Is it not commendable that i actually saw a problem that was there that nobody saw and noticed?
            People thought i was crazy sending a lot of posts
            • necrevistonnezrN
              necrevistonnezrN
              It’s not what you communicated but how.
              And I believe it‘s far more commendable that @girish kept his patience, analyzed your particular problem (no one else reported something similar), reported it upstream, and merged the fix himself, all within hours. And all without an SLA.
              So credit where credit is due.
              • M
                mmtrade
                @necrevistonnezr who the hell are you? all this ass licking... well i was never referring to you.
                @girish i actually did not understand what the problem was but you helped track it down.
                meanwhile is the update currently running on the cloudron?
                • J
                  #28
                  @mmtrade I am afraid such language is just unacceptable . worse, you seem just unaware, intentionally or not about your tone. the update is not running on Cloudron, but you need to make the change as suggested by @girish . I will lock this thread but we are having none of this tone here.
                  • J joseph locked this topic on
