  3. Teamspeak
Teamspeak
11 Posts 7 Posters 3.0k Views 7 Watching
  • nebulonN Away
    nebulonN Away
    https://www.teamspeak.com/en/downloads/
    murgeroM 1 Reply Last reply
      murgeroM Offline
      murgeroM Offline
      murgero
      @nebulon This would be pretty cool - but Teamspeak does not follow the Open Source licensing cloudron uses.
      Mumble would be a nice alternative as well.
      https://urgero.org
      • M Offline
        M Offline
        msbt
        I've built that a while ago and it still works (even though it needs a start/stop sometimes when rebooting the server): https://git.cloudron.io/msbt/teamspeak-app
        • W Offline
          W Offline
          will
          Team Speak is big, I'd see it as a platform win, even if I don't personally use it, I know a few that do.
          • ? Offline
            ? Offline
            A Former User
            A goode Idea, i hope you will add the app soon.
            • nebulonN Away
              nebulonN Away
              I've forked the repo now into https://git.cloudron.io/cloudron/teamspeak-app and updated the app to use the latest upstream version. @msbt thanks a lot for the work!
              @msbt do you know more about the start/stop issue on server reboot? The package as such already works really well during my limited tests so far 🙂
              Also the free version allows 32 concurrent users. It would be great to get the app package to work with a commercial license as well. If anyone knows how this is usually done, please let us know so we can make sure it somehow is possible.
              ? 1 Reply Last reply
                ? Offline
                ? Offline
                A Former User
                @nebulon How can i install the Teamspeak app at my cloudron? Is that at this time possible e.g with the Cloudron Build Service?
                • nebulonN Away
                  nebulonN Away
                  @timo you can clone the mentioned git repo and then use the cloudron cli tooling to build a package. You can read up on the process at https://cloudron.io/documentation/custom-apps/tutorial/
                  However we will likely publish the app in the coming days, so you might as well wait for that to happen.
                    We just had a 2 hour long teamspeak call with the app on Cloudron, works great! @nebulon will publish it to unstable tomorrow.
                    • nebulonN Away
                      nebulonN Away
                      This is now published as unstable until we got some feedback to mark it stable: https://forum.cloudron.io/topic/2121/teamspeak
                      • D Offline
                        D Offline
                        DigitEgal
                        wrote on last edited by DigitEgal
