  3. Beginner's Guide: Hugo + Gitlab CI + Surfer
23 Posts 7 Posters 9.5k Views 7 Watching
  • V
    V
    vjvanjungg
    wrote on last edited by vjvanjungg
    There are different approaches to this. This is one way based on another Hugo CMS post here -- I hope it helps someone!
    On your local machine, you'll need to install first:
    • Git (https://git-scm.com/downloads)
    • Hugo (https://gohugo.io/getting-started/installing/)
    • Yes, and create a GitLab account!
    Note: You will need to use a Cloudron or other self hosted gitlab instance. The Surfer and GitLab apps are both available on Cloudron. You would need to host your own gitlab-runner for this to work.
    After creating a GitLab account, you can log in to create a Blank project like this:
    It should look like this after the project has been created:
    To verify your Git & Hugo install on the local machine, you can run in your Mac Terminal/Windows cmd:
    git --version
    hugo version
    From here we can begin the fun part. All the commands needed are below. I have taken the screenshots of command by command.
    You can copy/paste and hit Enter/Return in your Terminal for each one to run and see the results.
    Remember to change the link to your GitLab project in the line beginning with git remote add below. We start with this line:
    hugo new site quickstart
    cd quickstart
    git init
    git remote add origin https://gitlab.com/vjvanjungg/hugo-surfer-demo.git
    git submodule add https://github.com/budparr/gohugo-theme-ananke.git themes/ananke
    echo theme = "ananke" >> config.toml
    hugo new posts/my-first-post.md
    hugo -D
    Then, at command #11 if you're using Visual Studio Code or any other code editor you like, open it up to add a new file called .gitlab-ci.yml:
    Adding .gitlab-ci.yml:
    The content of the file .gitlab-ci.yml is as follows. If you're hosting Surfer at a different url, remember to change it from surfer.demo.cloudron.io below to your url.
    stages:
      - build
      - deploy
    variables:
      GIT_SUBMODULE_STRATEGY: recursive
    build:
      image: monachus/hugo
      stage: build
      script:
      - hugo
      artifacts:
        paths:
        - public
      only:
      - main
    deploy:
      image: node:latest
      stage: deploy
      script:
      - npm -g install cloudron-surfer
      - surfer put --token $SURFER_KEY --server surfer.demo.cloudron.io public/* /
      only:
      - main
    After this, get the access token from Surfer:
    Then, go to your GitLab project --> Settings --> CI / CD. Find the Variables section and click Add Variable:
    And all you need now is to run the rest of the commands, they are:
    git status # just to see the file status not 100% necessary
    git add . # the dot means add everything
    git commit -m "Push to gitlab" # commit with any note/message you like
    git push -u origin main # push local files to remote GitLab project
    When you first do git push on your computer, you may be asked to enter your GitLab credentials. And voila, you're done!!
    After git push, you can see the magic happens in GitLab. The blue clock means the pipeline is running.
    After it succeeds, it will show:
    Navigate to your Surfer url, and enjoy your new site!
    😀 I hope it helps! This is the least I can do for a wonderful community that has helped me so much.
    girishG A 2 Replies Last reply
    • V vjvanjungg
      git --version
      hugo version
      cd quickstart
      git init
      hugo -D
      stages:
        - build
        - deploy
      variables:
      build:
        stage: build
        script:
        - hugo
        artifacts:
          paths:
          - public
        only:
        - main
      deploy:
        image: node:latest
        stage: deploy
        script:
        only:
        - main
      @vjvanjungg very nice, concise and crisp reading! Don't you need to setup a build server for the gitlab pipeline to work? Or did I miss that part in the tutorial?
      V ? 2 Replies Last reply
        V
        V
        vjvanjungg
        @girish thanks, we’re just letting the gitlab ci do the work, that’s how i understand it now. if that what u mean be build server, enlighten me otherwise
        • V vjvanjungg
          git --version
          hugo version
          cd quickstart
          git init
          hugo -D
          stages:
            - build
            - deploy
          variables:
          build:
            stage: build
            script:
            - hugo
            artifacts:
              paths:
              - public
            only:
            - main
          deploy:
            image: node:latest
            stage: deploy
            script:
            only:
            - main
          A
          A
          adrw
          @vjvanjungg Great tutorial! I wouldn't have guessed it'd be so easy to have a full CI + deploy for a static site all within Cloudron.
          V 1 Reply Last reply
            A Former User
            wrote on last edited by [[global:former-user]]
            @girish This appears to be on gitlab.com so it uses their shared CI runners.
            @vjvanjungg I would suggest adding a note about using a Cloudron or other self hosted gitlab instance. You would need to host your own gitlab-runner for this to work.
            I am now realizing that I didn't include this in my guide...
            • ? A Former User
              @atrilahiji said in Beginner's Guide: Hugo + Gitlab CI + Surfer:
              Yes, my bad, I missed the gitlab.com URL !
                A Former User
                Either way guides like this are perfect. IMO git driven static sites via static site generators are the best way to do static sites. No sense having a server or DB behind a site to serve articles or add new pages.
                Best part is, if you want to roll back a change you have the entire history of your site available as "backups" on git. Just revert a commit. 🙂
                • A adrw
                  V
                  V
                  vjvanjungg
                  @adrw yesh, me too when i saw it live! shout out to @atrilahiji too, if you haven’t watched his video come and watch it , it’s what inspired this one with great info:
                  https://video.lahijiapps.dev/videos/watch/3540b0bb-553f-43bb-8087-fa8e26fd0d46
                  ? 1 Reply Last reply
                  • V vjvanjungg
                    A Former User
                    @vjvanjungg glad it could help! I’m hoping to get around to making more guides for things but I do this reactively mostly. Perhaps a guide for building basic Vue frontend apps or personal sites?
                      does gitea or gogs not have any CI?
                      girishG ? 2 Replies Last reply
                        @robi I think they only integrate with existing CI systems like drone.
                          A Former User
                          @robi Drone is the best one right now. @fbartels did offer to package it if there was interest and I believe he wanted it to be sponsored. I would check that out.
                          fbartelsF 1 Reply Last reply
                          • ? A Former User
                            fbartelsF
                            fbartelsF
                            fbartels
                            Drone indeed integrates quite easily with Gitea. More information on my app offering can be found at https://forum.cloudron.io/topic/3350/offered-drone-ci-on-cloudron
                            The one thing I particularly like is that I only need the "Dashboard" to be centrally hosted, all the job runners can run inside private networks. The runner is a small golang binary that can easily be launched with docker-compose. This allows me to simply start the runner on whatever device I am currently working (desktop, laptop, chromebook, mini homeserver).
                            This is my drone configuration to build my hugo site and deploy it to my surfer instance:
                            kind: pipeline
                            concurrency:
                              limit: 1
                            steps:
                              - name: submodules
                                image: alpine/git
                                commands:
                                  - git submodule update --init --recursive --remote
                              - name: build
                                image: plugins/hugo
                                settings:
                                  hugo_version: 0.79.0
                                  extended: true
                                  validate: true
                              - name: deploy
                                image: 'fbartels/cloudron-surfer:5.12.2'
                                environment:
                                  SURFTOKEN:
                                    from_secret: surftoken
                                commands:
                                  - surfer --version
                                  - touch public/ # touch folder to avoid problems with timestamps
                                  - surfer put --token $SURFTOKEN --server blog.9wd.eu ./public/* /
                                when:
                                  branch:
                                    - master
                                  event:
                                    exclude:
                                      - pull_request
                              - name: Notification Rocket.Chat
                                image: rmilewski/drone-rocket:latest
                                when:
                                  status:
                                    - success
                                    - failure
                                settings:
                                  webhook: https://chat.9wd.eu/hooks/$(ROCKETSECRET)
                                  username: rocket.cat
                                  channel: drone
                                  color:
                                    - value: green
                                      when:
                                        DRONE_BUILD_STATUS: success
                                    - value: red
                                      when:
                                        DRONE_BUILD_STATUS: failure
                                  message:
                                    - value: "Build: ${DRONE_BUILD_NUMBER} succeeded. Good job."
                                      when:
                                    - value: "Build: ${DRONE_BUILD_NUMBER} failed. Fix me please."
                                  text: ${DRONE_COMMIT_MESSAGE}
                                  fields:
                                    - title: Author
                                      value: ${DRONE_COMMIT_AUTHOR}
                                    - title: Demo
                                      value: "This field will only be visible if the current branch: ${DRONE_COMMIT_BRANCH} is master or production"
                                      when:
                                        DRONE_COMMIT_BRANCH:
                                          - master
                                          - production
                            • fbartelsF fbartels
                              kind: pipeline
                              concurrency:
                                limit: 1
                              steps:
                                - name: submodules
                                  image: alpine/git
                                  commands:
                                - name: build
                                  image: plugins/hugo
                                  settings:
                                    extended: true
                                    validate: true
                                - name: deploy
                                  environment:
                                    SURFTOKEN:
                                  commands:
                                    - surfer --version
                                  when:
                                    branch:
                                      - master
                                    event:
                                      exclude:
                                        - pull_request
                                  when:
                                    status:
                                      - success
                                      - failure
                                  settings:
                                    channel: drone
                                    color:
                                      - value: green
                                        when:
                                      - value: red
                                        when:
                                    message:
                                        when:
                                    fields:
                                      - title: Author
                                      - title: Demo
                                        when:
                                            - master
                                            - production
                              @fbartels IIRC, a complication with packaging drone was that it required ENV vars to be set before the app is even started. Like you have to select the integration type etc. Is that still the case? If so, how would a Cloudron installation UX for this look like? Just choose some default and let the user edit the config file?
                              robiR fbartelsF 2 Replies Last reply
                                @girish bring up the app with first run instructions then on restart it reconfigures to prod.
                                  fbartelsF
                                  fbartelsF
                                  fbartels
                                  @girish kind of what @robi said. At first startup it creates a config file in the app that still needs to be manually edited in regards to where Gitea can be reached as well as its configured client id and secret.
                                  I did add you to the repo a while ago, so you can also have a direct look at https://github.com/fbartels/cloudron-drone-app/
                                    @fbartels said in Beginner's Guide: Hugo + Gitlab CI + Surfer:
                                    I'm getting a 404 there.
                                    ? fbartelsF 2 Replies Last reply
                                      A Former User
                                      @jdaviescoates Its a private repo. He'd have to invite you to it via your Github account.
                                        fbartelsF
                                        fbartelsF
                                        fbartels
                                        @jdaviescoates it's a private repo. You can get access by sponsoring me on GitHub. More details at https://forum.cloudron.io/topic/3350/offered-drone-ci-on-cloudron
                                          A Former User
                                          @fbartels Beat me to it :^)
                                          fbartelsF jdaviescoatesJ 2 Replies Last reply
