  3. Cloudron stuck
Cloudron stuck
29 Posts 4 Posters 12.0k Views 4 Watching
  • MattPlayGamezM MattPlayGamez
    @girish
    Here is the complete log file: https://paste.cloudron.io/nozeguyopi.sql
    PS: i use ubuntu-20.04.2-live-server-amd64.iso
    @mattplaygamez Right, it seems to be same error as what @ensarda faced. "Error response from daemon: network cloudron not found." . For some reason, the docker images and configuration have gone missing. Best bet is to start afresh. When you start afresh, can you please check if docker is already installed in your iso (it shouldn't be).
    MattPlayGamezM 1 Reply Last reply
      @ensarda yes, please. Let me know if it re-errors. Would like to get this sorted out.
      A Former User
      @girish Ok i've done a full reinstall no docker (made sure) and reinstalled and tried to install an app. It first looked to have the same issue was stuck for a while i just left it came back and boom it was installed and worked promptly after that (I installed to my main domain not a sub domain) I am having an issue with the image it loads works but has issues maintaining a stable connection. Time to hit the guacamole forums i think
        MattPlayGamezM
        MattPlayGamezM
        MattPlayGamez
        @girish TY so much. For your time and @ensarda you too.
        You're really a great community. Have a nice day/night.
          MattPlayGamezM
          MattPlayGamezM
          MattPlayGamez
          @girish another question I just want to get to cloudron apps, but I get this screen. Do you know what's wrong?Knipsel.PNG
            @mattplaygamez You have to visit my.domain.com to see the apps. Are you using the wildcard DNS provider?
              MattPlayGamezM
              MattPlayGamezM
              MattPlayGamez
              @girish yes
                @girish yes
                MattPlayGamezM
                MattPlayGamezM
                MattPlayGamez
                @girish if I go to vpn.cloudron.domain.ga works. But my.cloudron.domain.ga (err_ssl_version_or_cipher_mismatch) doesn't work.
                • MattPlayGamezM
                  MattPlayGamezM
                  MattPlayGamez
                  @girish
                  I can't log in / authenticate into OpenVPN I filmed it
                  please take a look at.
                    @girish
                    @mattplaygamez might be better next time to create a new forum thread for separate issues.
                    From your video, I think what is misunderstood is, that the config files for admins will use the user/usernames from your Cloudron, so if you Cloudron user is called foobar then put that username in the config file for the admin role. Maybe we can make this clearer in the docs.
