  2. Matrix (Synapse/Element)
  3. Voice and Video Calls to device on different network not working
video callaudio callnot working
11 Posts 4 Posters 6.6k Views 4 Watching
  • K Offline
    K Offline
    karthiceaswar
    so, i set up matrix synapse. chat room, messages all working. But when i try a 1 on 1 video call - *it works when both devices on same network(same home wifi). But when i try when one device is connected to a different network no success. Its stays at the connecting screen. I even opened all ports to all protocol in my vps's vnc subnet ( i am using oracle ubuntu instance - no firewall in ubuntu). What am i missing. I have been at it for more than two days. I thought the problem was with cloudflare and hence switched back to my domain providers dns NS. (haven't done federation yet) both chats are verified.
    nebulonN BrutalBirdieB 2 Replies Last reply
    • K karthiceaswar
      @karthiceaswar can you see any hints about webrtc/ICE in the app logs or browser console logs?
      I assume something does not work with connection negotiation.
      K 1 Reply Last reply
      • K karthiceaswar
        BrutalBirdieB Offline
        In Firefox you got about:webrtc where you can check webRTC connections for errors.
        Maybe check that and send the log and screenshots.
        Also in about:config you can set media.peerconnection.ice.relay_only to true to force the usage of the turn server.
        K 2 Replies Last reply
        • BrutalBirdieB BrutalBirdie
          K Offline
          K Offline
          karthiceaswar
          @brutalbirdie so it doesn't concern about my server setup ?
            K Offline
            K Offline
            karthiceaswar
            @nebulon How do i see it ?
              K Offline
              K Offline
              karthiceaswar
              @brutalbirdie my about:webrtc logs
              I couldn't make any of it.
              • K karthiceaswar
                @karthiceaswar from the logs it looks like it is unable to find a direct connection between the two clients for webrtc. In such a case it should fallback to using the turn server for relay but also that doesn't seem to work out.
                The turn server requires your firewall to be open for connections at 3478,5349 (udp and tcp) and a whole port range from 50000 to 51000 (udp)
                Maybe that is the issue?
                  K Offline
                  K Offline
                  karthiceaswar
                  wrote on last edited by karthiceaswar
                  @nebulon as for the firewall in my server i have opened up all ports and connection. Those ports are already open. Do I need to set port rule in Docker (is it actually possible) ?! This is my security list for the vnc rule. msedge_uJN7TSoa6R.png
                  • K karthiceaswar
                    @karthiceaswar Cloudron manages the server local firewall (iptables and docker rules) automatically, so you don't have to tweak the firewall of the server itself. I was more referring to any potential external firewall, but as you've mentioned this is all open as well.
                    To be honest, those webrtc issues are always hard to debug 😕
                    Have you tried to reach out to the upstream element developer community as well?
                      K Offline
                      K Offline
                      karthiceaswar
                      @nebulon Nope. I tried with different client too. But no success. Man....Its a bummer. I really need that 1 to 1 Video and audio calls to work. I even purged netfilter-persistent iptables-persistent. No success. It only works on same network. Anyway thanks for the effort.
                        If you can get logs from the client on the remote end of the call, it will tell you what's not connecting / failing.
