  3. Presearch node - Decentralized Search Engine
8 Posts 4 Posters 2.5k Views 4 Watching
    https://presearch.org/
    Presearch is a Decentralized
    Search Engine
    Search privately, receive better results and get rewarded with the Presearch decentralized search engine, powered by blockchain technology.
    Staked rewards for running self-hosted nodes.
    https://nodes.presearch.org/run
    docker image available.
      Where is the github repo or the selfhosting instructions?
        @girish check the second link
          Ah ok. AFAICT, you can run a node yourself and there are some rewards for running a node but you still have to visit their website to use search.
            @girish i think there is a local search interface but it also contributes to the whole since it's blockchain connected.
            • scookeS
              scookeS
              scooke
              I've been thinking of setting one up, but having it ready to install on Cloudron would be sweet. The only drawback could be some VPS hosts might not allow "crypto" on their servers and would shut me down. I'll have to read their ToS and ask.
              • scookeS scooke
                wrote on last edited by robi
                @scooke what they don't approve of is the mining aspect and high CPU usage which screws up their shared hosting experience for everyone on the same hosts.
                As I understand this is not mining but staking, hence not an issue and low CPU usage. Feel free to validate.
                • J
                  JLX89
                  AFAIK @robi is correct, you’re rewarded for basically hosting a node. I have a node setup and have transitioned most of my searches over to Presearch. I’m addition to Node Rewards, you also get around 0.10 PRE per search up to 10/day. It would be pretty awesome for be able to setup a node in Cloudron!
