  3. AppFlowy
AppFlowy
61 Posts 25 Posters 34.2k Views 35 Watching
    @tgatellier Use the +1 button on the first post to show support for the app. Leaving a comment doesn't count as a vote in the forum.
    • G
      G
      GP-S
      I just to signup to say I would loved to have this one. Sorry @girish don't have the reputation yet to upvote but strangely enough I have enough to comment.
      • C
        C
        cvachery
        I think I will try to package this application next
        Simply waiting for my other app to be accepted, so I can improve my packaging 🙂
        • T
          T
          taowang
          I saw Appflowy on github and tried it for a bit. The UI is very beautiful.
          Just wondering if notion has a good data security?
          I have all my doc stored on notion right now.
          If it is not secure, I will switch to self-hosting note-taking app.
          svtxS 1 Reply Last reply
          • T taowang
            svtxS
            svtxS
            svtx
            @taowang The question isn't so much whether Notion is secure or not (let's assume it's reasonably secure), the real question is whether or not it's trustworthy (let's assume it's not).
            𓇳𓏤𓅆𓈌𓏏𓏭
            micmcM 1 Reply Last reply
            • J
              jagan
              After the advent of AI, every company is data hungry and will not hesitate to use every data it has and gains access to, to use it to train its LLMs.
              • svtxS svtx
                micmcM
                micmcM
                micmc
                @svtx said in AppFlowy:
                This is exactly how one should see its stuff hosted on Big Tech services, unless you own the server.
                (coming soon...)
                • J jagan
                  micmcM
                  micmcM
                  micmc
                  @jagan said in AppFlowy:
                  I don't think this came with the advent of AI though, it's the exact business model of many Big Tech with their 'free' services (and even for paid, I would never put sensitive documents on 360, never).
                  (coming soon...)
                  • jdaviescoatesJ
                    This is now on 0.6.6
                    https://www.appflowy.io/what-is-new
                    https://github.com/AppFlowy-IO/AppFlowy/releases/tag/0.6.6
                    Here are Docker instructions:
                    https://docs.appflowy.io/docs/appflowy/install-appflowy/installation-methods/installing-with-docker
                    • F
                      F
                      fenohery
                      +1 for this app
                      • F fenohery
                        +1 for this app
                        @fenohery upvote the original post 🙂
                        • jadudmJ
                          jadudmJ
                          jadudm
                          Someone more familiar with packaging Cloudron apps would be able to answer better than me. However, I find that whenever a docker-compose.yml is involved, it is probably hard to move the app to Cloudron.
                          https://github.com/AppFlowy-IO/AppFlowy-Cloud/blob/main/docker-compose.yml
                          In this case:
                          • It wants nginx. That might be avoidable, or it might be serving static assets/code for the app.
                          • It wants minio. This could probably be accommodated by requiring users to run minio on their Cloudron before installing this.
                          • It wants postgres, which might be able to be leveraged from the internal stack.
                          • It wants redis. Again, possibly from the default stack... I can't remember.
                          • gotrue is an auth component from supabase. This will need its own container, and may (or may not) play nice with the SMTP/OAuth running on Cloudron.
                          • appflowy_cloud is the hosted app. It wants its own container, and configuration information for all of the services included.
                          • admin_frontend has its own Dockerfile. I haven't looked. Looks like more things.
                          • ai. I have no idea. It looks like it wants some kind of OpenAI. This is getting heavy in terms of resources.
                          • appflowy_history is... another Dockerfile. Looks like a rust application that has been Dockerized.
                          The problem, I think, is that Cloudron assumes/is structured such that applications run as single containers. The compose is suggesting that this application has a number of independent components. Perhaps those could be bundled up/run separately... but, it might be a real trick to make work.
                          This isn't to say it isn't possible, but that's what I see that needs to run, and it isn't clear to me that this is an easy app architecture to move over to Cloudron. YMMV, etc.
                          I use Cloudron on a DXP2800 NAS w/ 8TB in ZFS RAID1
                          • D
                            D
                            Dont-Worry
                            +1 for Appflowy. Very very high value added.
                            • jadudmJ jadudm
                              In this case:
                              P
                              P
                              plusone-nick
                              @jadudm so what you're saying is implementing docker-compose into Cloudron would fix this and a ton of other use cases....🫡🤝🤓
                              ✌💙+1
                              • T
                                T
                                tgatellier
                                +1 for this app, waiting so much to have it on cloudron
                                • micmcM
                                  micmcM
                                  micmc
                                  Seems like we may have missed this new Self-Hosted cloud version named AppFlowy Cloud.
                                  https://docs.appflowy.io/docs/guides/appflowy/self-hosting-appflowy
                                  https://github.com/AppFlowy-IO/AppFlowy-Cloud/blob/main/doc/DEPLOYMENT.md
                                  While waiting for apps to be added to Cloudron, hopefully folks at least take the time to experiment by yourself and try to install the app yourself first on another server, that you might learn a thing or two, and eventually come to integrate apps to Cloudron yourself 😉
                                  (coming soon...)
                                  D 1 Reply Last reply
                                  • micmcM micmc
                                    D
                                    D
                                    Dont-Worry
                                    wrote on last edited by Dont-Worry
                                    #37
                                    @micmc I tried, many times actually. Never managed to make it work by myself. Maybe I'm stupid.. This is why I use cloudron..
                                    • A
                                      A
                                      actuarch
                                      +1 for AppFlowy
                                      • marcusquinnM
                                        marcusquinnM
                                        #39
                                        Updated the screenshots above, as it's developed a lot since I first posted this.
                                        Does seem like a very high value win if we can get this packaged here.
                                        • GengarG
                                          GengarG
                                          Gengar
                                          wrote on last edited by Gengar
                                          #40
                                          I've just discovered AppFlowy and this app seems awesome ! Would love to see it in Cloudron. I'm a notion power user, and I can't wait to ditch notion.
                                          But as @jadudm said, seems like docker-compose based app are not easy to convert to a single dockerfile to work with Cloudron...
