  2. Package development
  3. Building custom app - authentication problem
33 Posts 5 Posters 7.2k Views 6 Watching
    hm so the app was in error state and thus stopping it was blocked, that is to be expected. However it should certainly not bring down the whole dashboard.
    • E
      E
      ekevu123
      Yep, I agree, but it did - and uninstalling the app via CLI immediately solved it.
      • E
        E
        ekevu123
        wrote on last edited by ekevu123
        #23
        What's the best way to specify the docker image tag if I don't do this in the Cloudron Manifest or the Dockerfile?
        EDIT: --tag did that
        • E ekevu123
          @ekevu123 said in Building custom app - authentication problem:
          FWIW when I am building a custom app and I make changes to the Dockerfile, it is my standard process to uninstall the last app version before seeking to build and deploy the next version.
          Technically this might be unnecessary, but for my little brain, I find it easier to know that I am starting 'clean'.
          I usually uninstall via the app's settings screen, but I guess from CLI is same and might be easier if you're working on command line anyway.
          I also use a little script cld.sh (call it whatever you want, I save keystrokes where possible) :
          #/bin/bash
          docker build --no-cache -t $1 .
          docker push $1
          cloudron install --image $1
          and I run this it this : ./cld.sh <repository_url>/<app_name>:<tag>
          I hack my way through multiple trial-and-error builds, and this saves a lot of time, keystrokes and typos.
          Maybe you have your own workflow efficiencies 😄
          • E
            E
            ekevu123
            I would probably do the same, but it doesn't help me in this case, because I am not overriding an existing installation. Instead, I just get a faulty installation in the first place.
            • E
              E
              ekevu123
              To summarise, my issue is this. When running "cloudron build", I get this error:
              error parsing HTTP 403 response body: invalid character '<' looking for beginning of value: "<html>\r\n<head><title>403 Forbidden</title></head>\r\n<body>\r\n<center><h1>403 Forbidden</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n"
              Failed to push image (are you logged in? if not, use "docker login")
              But I ran docker login before this step. I completely deleted all Cloudron CLI configuration and re-installed it without any effect.
                @ekevu123 I would first check if docker push works? Can you confirm ?
                I also found two related links:
                • https://superuser.com/questions/1389039/docker-error-parsing-http-403-response-body-invalid-character-looking-for says this might be cause docker push access does not work from network
                • https://stackoverflow.com/questions/32900830/docker-http-code-403-while-uploading-metadata-invalid-character-looking-f says it's maybe an auth issue with docker hub
                • E
                  E
                  ekevu123
                  No, I am getting the issue when running docker push.
                  I also suspect that it is an IP restriction because I am currently in Malaysia. So, I contacted Docker support about it. The only other solution I could think of then would be to change the docker repo provider to Google or something.
                  • E
                    E
                    ekevu123
                    #29
                    Docker pull and docker push works fine now and docker didn't confirm any IP restriction.
                    I could now build the app using cloudron build but I am getting this when I am trying to install it:
                    App installation error: Installation failed: Unable to pull image PATH:tag. message: (HTTP code 404) unexpected - pull access denied for PATH, repository does not exist or may require 'docker login': denied: requested access to the resource is denied statusCode: 404
                    But the path is right, I used --set-repository to check and it's the same I use for docker pull and docker push.
                    Is it possible that for whatever reason Cloudron cannot authenticate with Docker in my case?
                    EDIT: It works when making the repository public.
                    • E ekevu123
                      BrutalBirdieB
                      BrutalBirdieB
                      @ekevu123
                      https://docs.cloudron.io/settings/#private-docker-registry
                      Did you take this into account?
                      • E
                        E
                        ekevu123
                        Yes, I did.
                        I corrected some other errors and finally got the message "app is installed" at some point without any error message. However, once that is the case, I cannot access the dashboard anymore (it stays grey, see above) until I uninstall the app.
                        Maybe that is a support case after all where you ssh into my instance?
                          @ekevu123 If installing a custom image is bringing down the dashboard, that is something we would want to look at. Can you please reach out at support@cloudron.io, interested to see what's going on.
                            @ekevu123 Thanks for the report! There was indeed a bug that the dashboard code throws an error when an app does not use any addons. https://git.cloudron.io/cloudron/box/-/commit/e02f3d70649c75c64e4126f1deea45b3456277a0 is the fix.
