  3. Open WebUI - ChatGPT-Style Web UI Client for Ollama 🦙
19 Posts 6 Posters 18.7k Views 9 Watching
  • LanhildL
    LanhildL
    Lanhild
    wrote on last edited by Lanhild
    Hello everyone,
    I've successfully packaged open-webui | formerly known as ollama-webui for Cloudron.
    The application allows you to chat with a remote Ollama server.
    To see my package code: https://github.com/Lanhild/open-webui-cloudron
    The package is fully working as of today, Feb 14th. The only issue I'm facing and would require assistance with is this. If anyone has a clue about this one, feel free to make a PR.
    P.S.: If the Cloudron team wishes to manage the packaging for this app, I'll gladly hand in my code, just notify me!
    timconsidineT L 2 Replies Last reply
    11
    • LanhildL Lanhild referenced this topic on
      Nice work.
      You can use the CLOUDRON_APP_DOMAIN to form your OLLAMA_API_BASE_URL so it doesn't need to be done manually postinstall.
      LanhildL 1 Reply Last reply
        Nice work.
        LanhildL
        LanhildL
        Lanhild
        @robi Yeah, I know about this variable, but decided not to use it since you Ollama server might not be on the same domain as your Ollama-webui server. Thus the 'example.com' placeholder.
        • LanhildL Lanhild
          Hello everyone,
          @Lanhild fantastic !
          Well done and thank you 👏 🙏
          • LanhildL Lanhild
            Hello everyone,
            @Lanhild Hey, fantastic!
            Thank you for doing that.
            Please tell us how you found the packaging experience. For example, were the notes you needed all there? Did you see this thread beforehand? https://forum.cloudron.io/topic/2843/read-first-before-starting-to-package-an-app
            Also, what prompted you to package for Cloudron? Do you think you might suggest packaging to other developers now?
            • L LoudLemur
              LanhildL
              LanhildL
              Lanhild
              @LoudLemur All the information I needed were present in the Cloudron documentation.
              Some applications that I use (such as Ollama-webui) are not very resource hungry, therefore I wanted to have them on my Cloudron server rather than a dedicated server. Basically, reducing the amount of servers to maintain/update by having more services on my Cloudron.
              • LanhildL
                LanhildL
                Lanhild
                Changing topic name. See https://github.com/open-webui/open-webui/discussions/764
                • LanhildL
                  LanhildL
                  Lanhild
                  Stable packaging would need https://github.com/open-webui/open-webui/issues/255 to be resolved.
                  • LanhildL
                    LanhildL
                    Lanhild
                    I've opened https://github.com/open-webui/open-webui/pull/839, as a mean to comply with Cloudron packaging standards.
                    • LanhildL
                      LanhildL
                      Lanhild
                      Coming back with great news!
                      Open WebUI introduced today automatic releases with versions strings from the version field in the package.json file.
                      I also found the issue with document uploading, there was a missing environment variable.
                      I thoroughly tested the package, documented what I could/was necessary.
                      The package https://github.com/Lanhild/open-webui-cloudron is now fully working 🎉
                      robiR girishG 2 Replies Last reply
                      • LanhildL
                        LanhildL
                        Lanhild
                        An example of Open WebUI, hosted on Cloudron
                        • LanhildL Lanhild
                          @Lanhild Excellent, congrats! 👯
                          Make sure to see this bit of great news too, so it can be easily installed as a custom app: https://forum.cloudron.io/post/82990
                          • L
                            One thing I would like to be able to do is chat with my documents (.txt, .odf, .epub, .pdf, etc.)
                            GPT4all is meant to be able to do this but I wonder if open-webui might be able.
                            • L LoudLemur
                              LanhildL
                              LanhildL
                              Lanhild
                              @LoudLemur Open WebUI is indeed capable of this
                              • LanhildL Lanhild
                                @Lanhild said in Open WebUI - ChatGPT-Style Web UI Client for Ollama 🦙:
                                Could we just point it at a folder full of documents and say, "lets talk about this..." or do the documents need to be pre-processed, for example, converted into a .yaml or or something? I wonder how many e.g. Shakespeare plays I could give it at one go and how easy it would be to do something like this.
                                • coniunctioC
                                  coniunctioC
                                  coniunctio
                                  How do we install an app like this in Cloudron when it is not in the app store? I typically host docker apps on my NAS (QNAP Container Station) and then reverse proxy via Cloudron to those apps. I host Cloudron via a VM on the same NAS. What is the advantage to hosting open-webui natively within Cloudron versus as a docker contain and reverse proxying to it?
                                    Not sure if you are asking this question specific to openweb-ui or in general. But to answer in general, when you host apps on Cloudron, they have dns management, automatic certs, backups, updates, rollback, clone, automated email configuration, user integration (if the app supports it via ldap or oidc) etc. We also have some security requirements like running apps as readonly, run as non-root, sandboxed fs etc. This is the reason why we build our own packages.
                                    • LanhildL Lanhild
                                      @Lanhild I moved the repo here - https://git.cloudron.io/cloudron/openwebui-app . @vladimir-d has fixed a few things. You should also have access to the repo.
                                      Working on publishing this now.
                                        I have published this as unstable 🙂 Thanks a lot @Lanhild . Let's continue discussions in the category - https://forum.cloudron.io/category/185/openwebui
                                        • girishG girish locked this topic on
