BigBlueButton - web conferencing system for on-line learning
I took a brief look at the app and overall it appears to work. Thanks a lot!
Some things to improve:
- I was not sure how to login with the pre-setup admin, since I didn't know the admin email address
- The tests need also test admin login
- The tests need some code cleanup
- Since it is only the webfrontend as far as I can tell, the icon has to somehow reflect this
- The postinstall docs need to mention the fact that the backend has to be adjusted to not use the default test backend
@nebulon said in BigBlueButton - web conferencing system for on-line learning:
- The Admin E-Mail address is the
Mail FROM Addressaka.CLOUDRON_MAIL_SMTP_USERNAMEvariable from e-mail addon also noted in thePOSTINSTALL.md. As far as I am aware of I can not write thePOSTINSTALL.mddynamically to display the envCLOUDRON_MAIL_SMTP_USERNAME.
So either I have to do a better job to explain how to get the E-Mail address from Terminal or the log or use a static e-mail address.
What would be the status quo to for this type of issue? - Will add the test for admin login as well (above issue again, hmm so static admin e-mail would be better?)
- Understandable
- Greenlight has no own Icon sadly, I would suggest the BBB Icon but in Green?
- Will add that.
Cheers.
For the email address, we use
admin@server.localin such a case. Hopefully it is possible to change this later by the user, just like the pre-setup password?@nebulon said in BigBlueButton - web conferencing system for on-line learning:
For the email address, we use admin@server.local in such a case. Hopefully it is possible to change this later by the user, just like the pre-setup password?
Yes e-mail and password can be changed.
And I will useadmin@server.local.Thanks for the input.
I'm assuming you're using BigBlueButton 2.3-alpha-2 as the basis for this?@jdaviescoates the Greenlight App is just the front end for BigBlueButton.
As @luckow mentioned BBB can be installed anywhere and Greenlight is just the front end which connects to a specific BBB instance or cluster to provide a UI etc.@BrutalBirdie said in BigBlueButton - web conferencing system for on-line learning:
As @luckow mentioned BBB can be installed anywhere and Greenlight is just the front end which connects to a specific BBB instance or cluster to provide a UI etc.Ah, yes. I actually realised Greenlight is just a front end because it's what we as the front end for the https://meet.coop BBB server.
I was just secretly hoping that because you'd posted about it in this thread about BBB itself, you were working on a package that included BBB itself too!
Hey @luckow can you share your insights about BBB as App in Cloudron?
Referring to this conversation:
@jdaviescoates said in Cloudron 5.6.2:
@BrutalBirdie said in Cloudron 5.6.2:
I remember a conversation about BBB as App not being a good idea.
It could possibly be that BBB recommends bare metal servers because freeswitch (which it depends on) works best like that?
https://docs.bigbluebutton.org/2.2/install.html#minimum-server-requirements
But at the same time I have also heard of people using BBB on a VPS without any real issue.
I'd definitely love to have a BBB app!
And I think that once 6.0 with it's unified dashboard (whatever that exactly turns out to be) is out it'll also be easier to have a whole separate VPS dedicated to just Cloudron + BBB, which would help too I imagine.
Is the development still going on? I host my church meetings in bbb so I need it like 3 times a week. I currently have a extra server for that which costs a lot. Would be nice to have it in Cloudron directly
I found a container directly from BBB https://hub.docker.com/r/bigbluebutton/bigbluebutton
Although they say not suitable for production use, I would still love it use it. Did someone try it? I can't get it to run on docker. -
Although they say not suitable for production use, I would still love it use it. Did someone try it? I can't get it to run on docker.@cyberfreakde I don't think anyone has started to package BBB for Cloudron yet as there isn't a stable BBB release that runs on Ubuntu 18.04 yet...
@jdaviescoates But if it is a docker container? I think it doesn't matter.
2.3-alpha-4 is out:
https://github.com/bigbluebutton/bigbluebutton/releases/tag/v2.3-alpha-4
@cyberfreakde said in BigBlueButton - web conferencing system for on-line learning:
I think it probably does matter, otherwise @staff likely would've started trying to package BBB already (rather than waiting for a stable version that runs on 18.04)
Technically speaking, @cyberfreakde is correct. It doesn't matter because container can even contain centos. But to keep our maintenance burden low, we only use Ubuntu 18 in containers. Mentally, this is the equivalent of having to maintain app packages for different distributions.
@girish bbb-install.sh supports installing BigBlueButton 2.3 and coturn on Ubuntu 18.04.
@robi said in BigBlueButton - web conferencing system for on-line learning:
Yes but 2.3 is not stable.
TL;DR
It's not time yet. ~ Sound warning!I also talked to Fred Dixon some weeks before last Christmas about the state of 2.3.
Here a quote from him, which I gather from my memory (all statements without guarantee):
We will not give a release date because we only ship a functional product and don't work with due dates.
This only sets false expectations and leads to bad code.I can share this 2.3-draft where you could get some information about current state of 2.3.
Lets talk BBB and turnserver.
There is a turn addon default by Cloudron.
Problem is, its a docker containercloudron/turn:1.1.0running on port:listening-port=3478 tls-listening-port=5349This turnserver is kinda useless.
In short terms, a app is needed for turn, so the turn can listen to port 80/443.
Why?
Company / School with a firewall.
Only Ports 80,443,22,993,587 outbound is allowed. (Everything else blocked).
The turn server should now act like as a MITM (big empasis - like a) so this client can use webRTC via turn.
But since it's running on port 5349/3478 its useless.afaik girish and nebulon are aware of this but it's not a big priority right now. (Which I fully support)
Also BBB takes a lot of resources. For running small sessions 2-5 People or even 10 it could work out.
But since BBB is running alongside other Apps this could lead to quite a problem if to many people turn on their webcam. -
TL;DR
Why?
But since BBB is running alongside other Apps this could lead to quite a problem if to many people turn on their webcam.@brutalbirdie said in BigBlueButton - web conferencing system for on-line learning:
Actually, I am just fixing this for 6.1. I am trying out https://jitsi.github.io/handbook/docs/devops-guide/turn and hopefully that works. The main motivation for us is to move to using kopano meet internally and I suspect maybe this use of different port is what is causing many issues (which have been reported on this fourm). I hope the config there works because https://github.com/coturn/coturn/issues/43 was initially closed stating it was not possible (i.e turn requires a dedicated server to run on 443!)
@girish That might also help nextcloud talk high perf backend too.
@doodlemania2 ARG I think I read something about nextcloud talk not support turnservers with TLS?
"(D)TLS is currently not supported by Nextcloud Talk and does not have any real security benefit anyway. For more details see the changelog below." -- https://help.nextcloud.com/t/howto-setup-nextcloud-talk-with-turn-server/30794/93703
So be aware of this.
What we really need then is a TURN server integrated with Nginx.
Doing a quick search I haven't found an extension for Nginx, but then I thought why not front the TURN server we have with Nginx as a proxy load balancer which can include port 80/443 and UDP ports.
This post goes into the configuration of something like that:
https://stackoverflow.com/questions/51566225/nginx-load-balancing-a-turn-server@staff could easily adapt this to handle non HTTP traffic via the TURN server and the rest going to the Apps.
@girish said in BigBlueButton - web conferencing system for on-line learning:
Did this get into 6.1?
