  3. ERPNext - cost-effective ERP solution
124 Posts 38 Posters 158.4k Views 43 Watching
  • njN nj
    Okay, here is the good news. Please try it out and let me know if it works.
    If you're not ready to build the image yourself, you can simply install the image that I created. cloudron install --image njsubedi/cloudron-erpnext -l erp.<yourdomain.tld>.
    ErpNext v14 is now available on Cloudron. See the README file for usage instructions.
    Features
    • ErpNext v14 - running on Frappe Framework v14
    • HRMS Module - Includes HR and Payroll modules
    • Plug n Play - Automatically configured to use the subdomain you install it on, no setup needed
    • Independent - Does not depend on Cloudron Addons for redis, mysql or such
    Gotchas
    • Installs its own database servers, but data resides inside /app/data, so it gets backed-up, no not a big issue
    • Hasn't been tested a lot, but it's working pretty fine
    • Multi-tenancy isn't set up, even though that's pretty trivial to do
    Good to know
    • After installation, look into /app/data folder using cloudron's file manager for a file that ends with -credential.txt.
    • Raise issues on Github if you run into problems, not here.
    @nj said in ERPNext - cost-effective ERP solution:
    Features
    Gotchas
    Good to know
    You are a Free Software hero right there, @nj !
    • njN nj
      Features
      Gotchas
      Good to know
      marcusquinnM
      marcusquinnM
      @nj 💯 bonus points to you sir! 👏
      • infogulchI infogulch referenced this topic on
      • subvenS
        subvenS
        subven
        wrote on last edited by subven
        #63
        Can somebody review the code?
        @girish what else needs to be done so that it can be released as an unstable app in the store?
        Some concerns:
        • only dev branch for hrms and payment module and no release (yes I'm aware that only the dev branch exists - this has to be adressed in the future)
        • does not use Cloudrons Redis
        • Will some of the database mitigations break the insallation in the future?
        I will wait until the unstable release at the Cloudron App Store and start testing then 🙂
        • njN
          njN
          nj
          I’ve added Cloudron LDAP support. I’ll push the changes this evening.
          I think I can do Cloudron redis too. Looks doable.
          I think after the default site is created, I can dump the db and import that to cloudron MySQL, but still ErpNext devs recommend Mariadb support only, and it needs the database name to be the same as the db user name. Unless there’s support from Cloudron devs, it’s a blocker. But I have set db path to be inside /app/data, so backup is not an issue. Also tried migration and backup-restore, which worked fine.
          Since I’m actively using it at my company I’ll keep supporting this app. Also Keycloak, Outline and Odoo.
          Founder / Coder • My Apps
          H L 2 Replies Last reply
          • njN nj
            H
            H
            hakunamatata
            @nj Thanks for your hard work with this! I am looking forward to the day this becomes available in the app store us n00bs. 😊
            • njN nj
              @nj What is the latest on Odoo? Is it still inching its way to beta on Cloudron?
              • njN nj
                Trailer 😉
                You know what's disappointing? I started packaging ERPNext for the HR module. Unfortunately, the HR Module is not available after installation. Now I'm here thinking where the hell it go, and why I spent weeks packaging something that doesn't have the particular module I was looking for. 🤦
                Update: Looks like version-14 of ERPNext does not have HR module. Only version-13 has it. 😕 Now packaging version 13.
                mdreiraM
                mdreiraM
                mdreira
                @nj ERPNext 14 also have an LMS, right?
                https://erpnext.com/open-source-education
                micmcM 1 Reply Last reply
                • mdreiraM mdreira
                  micmcM
                  micmcM
                  micmc
                  @mdreira said in ERPNext - cost-effective ERP solution:
                  Seem like yes, indeed, as it is written on the quoted page. And it seems to be very powerful as well.
                  (coming soon...)
                  mdreiraM 1 Reply Last reply
                  • micmcM micmc
                    mdreiraM
                    mdreiraM
                    mdreira
                    @micmc @nj Yes.
                    After reviewing Odoo and Flectra, in their community and enterprise versions, I think that ERPNext is a very good option because it is 100% free software.
                    And it has a lot of features.
                    As @nebulon says, it is a cost-effective ERP solution.
                    • mdreiraM mdreira
                      @micmc @nj Yes.
                      marcusquinnM
                      marcusquinnM
                      @mdreira The big gotchya with Odoo is that the most useful part of it, the Studio addon, is not in the community edition.
                      With ERPNext, their equivalent no-code custom data model builder is included.
                      • njN nj
                        Features
                        Gotchas
                        Good to know
                        B
                        B
                        benneic
                        • mdreiraM
                          mdreiraM
                          mdreira
                          wrote on last edited by mdreira
                          #72
                          @girish @nebulon so, could erpnext be a reality in Cloudron in the short term?
                          (I know you are working in the new update)
                          • P
                            P
                            privsec
                            Such a great solution and offering.
                            This would solve quite a few problems a client of mine is experiencing trying to solve.
                            Looking forward to this!
                            • mdreiraM
                              mdreiraM
                              mdreira
                              Wow, this app wishlist post started at 2018…
                              • mdreiraM mdreira
                                P
                                P
                                plusone-nick
                                @mdreira Yeahhh...all good things take time, plus ERP next at the time was not what it is now lol but that's even more reason to get it onboarded now =]
                                ✌💙+1
                                AizatA 1 Reply Last reply
                                • P plusone-nick
                                  AizatA
                                  AizatA
                                  Aizat
                                  @plusone-nick I'm hoping the Cloudron team will support to include this formally in Cloudron soon. There might be some hindrances, but I think it should work relatively fine now, right?
                                  • S
                                    S
                                    spacetime
                                    I add my request for ERPNext!
                                    • infogulchI
                                      infogulchI
                                      infogulch
                                      I was able to successfully build and run the package nj published on github for the last couple of months.
                                      It seems to work fine, though I have not had a chance to evaluate how the upgrade and backup/restore process goes (I still have concerns about how it would interact with cloudron long-term), and I've only just started setup for a few modules.
                                      From my (limited) experience, if you want to use ERPNext, be prepared for an extended commissioning phase. The product is both wide and deep, you will be taking considerable time to learn the ERPNext system and configuring it to work with your business process. ERPNext is moderately opinionated on how things should work, an approach I generally appreciate, but I found integration to be a big task as it pushed me to shift my expectation on how things should be organized to the "ERPNext-way". To be fair, this could be as much my ignorance of ERP systems in general as ERPNext's particular obtuseness, but I suspect the truth is that any large integrated bookkeeping system will exhibit similar commissioning/integration difficulties by the very nature of its size and scope.
                                      I don't mean to push anyone away from the product, just to lay out realistic expectations of how much effort it will take on your part to integrate a product of this scope into your business.
                                      • njN
                                        njN
                                        nj
                                        wrote on last edited by nj
                                        #79
                                        I have published an update for ERPNext on Github - cloudron-erpnext-v0.20.0 This version is stable, but has breaking changes from the first release, so instead of updating you'll need to export and re-import the documents manually. This won't be necessary from future updates.
                                        1. Built on the base image version 4.0 (Ubuntu 22.04), so the source code is much lesser and simpler.
                                        2. Uses Cloudron's redis service, as requested by one of the members.
                                        3. The webserver and supervisor run as a normal (non-root) user so it's a bit more secure
                                        4. Existing apps (frappe, erpnext) etc can be updated easily from the terminal. There will be no need to update this app anymore from this point onward.
                                        5. New apps (like hrms, frappedesk) can also be added or removed easily.
                                        6. LDAP Settings can be configured if needed using the included script.
                                        7. There's preliminary support for multi-site setup.
                                        I request someone to test this package and give some feedback. Thank you.
                                        If building the app sounds complex, you can simply use the existing package by running cloudron install --image njsubedi/cloudron-erpnext:20230104-200417-70210de70 -l erp.your-domain.tld
                                        Note: the latest image can be found at https://hub.docker.com/r/njsubedi/cloudron-erpnext/tags . Replace 20230104-200417-70210de70 with the latest tag.
                                        jdaviescoatesJ R 2 Replies Last reply
                                        • njN nj
                                          @nj great, thanks!
                                          @staff are you going to take a look at this and get it into the App Store?
                                          njN 1 Reply Last reply
