  2. Postiz
  3. Plan to drop postiz package from Cloudron
Scheduled Pinned Locked Moved Postiz
11 Posts 9 Posters 1.9k Views 9 Watching
    Just a heads up, new postiz versions require temporal-server which requires its own backup/restore hooks and thus would have to become a Cloudron addon. Since this is quite the obscure framework and not used by anything else on Cloudron, this is unlikely we will add this.
    This does mean that postiz cannot be updated and given the issues the app had from the get-go, it is pretty clear that upstream is not really intending this to be a production ready selfhosted app. We are thus considering dropping the package.
    If anyone has experience with temporal-server here and maybe more insights into how to properly handle this, we are happy to hear any input to possibly reconsider it for postiz.
    • nichu42N
      nichu42N
      nichu42
      I can understand they want to earn money with it. Too bad, I really hoped for an affordable solution for small non profits or hobby projects.
      Matrix: @nichu42:beeper.com
      • luckowL
        luckowL
        luckow
        From their FAQ:
        Can I self host Postiz all by myself?
        Definitely, we are trying to make Postiz to host as easy as possible, check our documentation to find out how
        • I
          I
          ikalou
          It looks like the package is gone from the cloudron supported apps, has anyone tried self-hosting it by following the official method as presented in their doc, with success? (https://docs.postiz.com/quickstart)
          I 1 Reply Last reply
          • I ikalou
            I
            I
            IniBudi
            @ikalou what should we do if the package is gone from the Cloudron supported apps? Could we still update it manually?
              Hello @ikalou
              One could fork the package https://git.cloudron.io/packages/postiz-app and make it a community app.
              This way it would continue existing with updates, but with maintenance by the Cloudron community.
                I just saw an interview with the postiz creator who describes the niche he filled and the popularity of his hosted service esp for agents, and how difficult the self hosted setup is.
                His comments indicated it is possible if everything is plumbed right, so it's not just a broken app like it seems.
                A bit more research and agentic help may reveal a path to working setups.
                • marcusquinnM
                  marcusquinnM
                  CA Maintainer Super Fan
                  • https://x.com/wickedguro/status/2067932365545165183?s=20
                    wrote on last edited by robi
                    @timconsidine can you fire up the custom package and test the X connector?
                      Here's the video:
                      • micmcM
                        micmcM
                        micmc
                        It's too bad this app has been abandoned. Yet, there's a full docker install and I might have missed it or upstream might have changed their but I haven't seen a trace of a mention about the use of a "temporal server" as a requirement to run this.
                        Anyway, on the other hand, there's a cool work around for anyone running Hermes can run the Postiz Skill within one's Hermes instance. https://postiz.com/hermes
                        There also is the option to run it from a N8N Node https://www.npmjs.com/package/n8n-nodes-postiz
                        Enjoy!
                        (coming soon...)
