  3. My installation keeps hanging at waiting for DNS for my.domain.com
installationdns
9 Posts 4 Posters 4.1k Views 4 Watching
  • F Offline
    F Offline
    Felix
    Hello,
    What could be causing this issue?
    I'm attempting to use a namecheap domain and and a vultr instance.
      Sometimes DNS takes a long time to fully propagate. In order to obtain SSL certificates, Cloudron has to wait for the DNS record (my.domain.com) to resolve correctly to the server's IP before proceeding during setup.
        @Felix You can check host my.domain.com on your laptop. Does it give the right IP? If Cloudron is still in the setup page, you can just systemctl restart box on the server and the setup page will come back up.
        • F Offline
          F Offline
          Felix
          It's been 24 hours and nothing.
          my.domain.com says:
          server IP address could not be found.
          I will try systemctl restart box and trying again. When you guys say a long time, do you mean like days? 😵
          • ? Offline
            ? Offline
            A Former User
            Have you configured your domain name to point at the IP?
            F 1 Reply Last reply
            • ? A Former User
              F Offline
              F Offline
              Felix
              @YurkshireLad
              I haven't. How do I do that with Namecheap? Thank you.
              • F Felix
                @YurkshireLad
                F Offline
                F Offline
                Felix
                @YurkshireLad
                I'll try it with this guide again:
                https://techwombat.com/how-to-point-domain-name-to-vultr-vps/
                  @Felix Are you using Cloudron's namecheap integration? i.e you choose namecheap as the provider in the initial DNS setup screen?
                  Can you send us the logs to support@cloudron.io? The log is at /home/yellowtent/platformdata/logs/box.log.
                    @Felix Did you manage to install it?
