  2. WordPress (Developer)
  3. How to fix SMTP after migrating from Managed to Unmanaged
Scheduled Pinned Locked Moved Solved WordPress (Developer)
mail
15 Posts 5 Posters 5.2k Views 5 Watching
  • jdaviescoatesJ Offline
    I just used the All in One Migration plugin to move a site from WordPress (Managed) to WordPress (Unmanaged).
    After I learned how to increase the max upload size so I could actually import my export, it all went really smoothly.
    But now SMTP isn't working and so it can't send emails.
    @d19dotca - how do I sort it? (I'm guessing you know as you've done this a migration a few times before)
    Thanks! 😄
    murgeroM 1 Reply Last reply
      Thanks! 😄
      murgeroM Offline
      murgeroM Offline
      murgero
      @jdaviescoates Does the unmanaged app need the SMTP plugin?
      https://urgero.org
      • murgeroM murgero
        BrutalBirdieB Offline
        @murgero said in How to fix SMTP after migrating from Managed to Unmanaged:
        https://git.cloudron.io/cloudron/wordpress-unmanaged-app/-/blob/master/CloudronManifest.json
        Sendmail Cloudron Addon is present.
        "addons": {
            "mysql": {},
            "localstorage": {
              "ftp": {
                "uid": 33,
                "uname": "www-data"
            "sendmail": {},
            "scheduler": {
              "wpcron": {
                "schedule": "*/1 * * * *",
                "command": "/app/pkg/cron.sh"
            "redis": {}
        I have a wordpress inside a lamp-app and needed to install WP-Mail SMTP and these are my settings.
        # Mail sender
        * info@domain.tld
        # E-Mail Send Service
        * SMTP-Connection
        # SMTP-Server
        * mail
        # encryption
        * none
        # SMTP Port
        * 2525
        # SMTP Username
        * lampphp72.app@domain.tld
        # SMTP Passwort
        Check vars in cloudron console
        • BrutalBirdieB BrutalBirdie
          "addons": {
              "mysql": {},
              "localstorage": {
                "ftp": {
                  "uid": 33,
                  "uname": "www-data"
              "sendmail": {},
              "scheduler": {
                "wpcron": {
              "redis": {}
          # Mail sender
          * info@domain.tld
          * SMTP-Connection
          # SMTP-Server
          * mail
          # encryption
          * none
          # SMTP Port
          * 2525
          # SMTP Username
          # SMTP Passwort
          murgeroM Offline
          murgeroM Offline
          murgero
          wrote on last edited by murgero
          @BrutalBirdie OK - in the unmanaged Wordpress app, did you also install the WP-mail SMTP plugin? Not to be confused with the sendmail addon from cloudron.
          https://urgero.org
          BrutalBirdieB jdaviescoatesJ 2 Replies Last reply
          • murgeroM murgero
            Like I wrote, I do not use the unmanaged wordpress app, I use the lamp-app.
              murgeroM Offline
              murgeroM Offline
              murgero
              @BrutalBirdie Oh, you're not the original poster 😖 sorry!
              https://urgero.org
                I think that's the missing bit - WP-Mail SMTP needs to be installed and has to be installed. After that, if you restart the app, the package will automatically re-configure that plugin to use the sendmail addon credentials.
                • d19dotcaD Offline
                  d19dotcaD Offline
                  d19dotca
                  Okay, so in my experience using WP-All-In-One Migration plugin, you want to make sure the "Do not replace email domain" is selected, assuming you're putting it eventually back on the original domain. Otherwise you will need to leave it unchecked so that it carries over and takes on the new SMTP settings as that not only impacts the email domain shown on the public site but the settings in WP Mail SMTP too.
                  Dustin Dauncey
                  www.d19.ca
                    @girish said in How to fix SMTP after migrating from Managed to Unmanaged:
                    It is installed, it's just the credentials are wrong (I think), because they've been copied over from the Managed one when I imported the All in one Migration export files with the db and files etc.
                    • murgeroM murgero
                      Just to say, no, the WP Mail SMTP plugin is installed by default in both the Managed and Unmanaged Wordpress apps.
                      • d19dotcaD d19dotca
                        @d19dotca said in How to fix SMTP after migrating from Managed to Unmanaged:
                        Aha.
                        I didn't actually see any options, will check next time I do it!
                        Thanks. And yes, it's at the same domain.
                        But still not really sure what to do now, given I didn't select "Do not replace email domain".
                        Where and when do you see that option? When creating the export? Or when importing the export?
                        Thanks!
                        d19dotcaD 1 Reply Last reply
                          @jdaviescoates Just restart the app. Repair -> Restart. It will fix up the credentials of the SMTP plugin.
                            @girish worked, thanks! Should've thought to just try that in the first instance! 🙂
                              Aha.
                              Thanks!
                              d19dotcaD Offline
                              d19dotcaD Offline
                              d19dotca
                              @jdaviescoates looks like it’s already fixed but for future reference those options are on export (too late by time you’re doing import unfortunately). There’s an advanced settings collapsible item (collapsed by default so not easy to see) above the export button. It’ll give you a bunch of options such as the email ones plus others like not exporting spam comments, revision history, plugins, themes, etc.
                              Dustin Dauncey
                              www.d19.ca
                                @d19dotca great, thanks 🙂
