  2. Off-topic
  3. How much does VPS location matter?
20 Posts 10 Posters 9.6k Views 11 Watching
  • L Offline
    L Offline
    LeeW
    I am moving away from shared hosting in favour of Cloudron. Trying to decide on which VPS provider to use. My intention was to use DigitalOcean in the UK. Three of the key sites I am moving are relevant to the UK market more than anything.
    That said I see Hetzner Cloud pricing is so much cheaper. Not that I am a cheapskate by any means but I am wondering whether it really makes that much difference whether I go with DigitalOcean in the UK or Hetzner in Germany.
    All sites will be using Cloudflare.
    I am guessing here that the only likely difference will be that it will be slightly longer to load the site and pages if hosting in Germany vs the UK but enough for visitors to notice? Not sure.
    I suspect there are a lot more experienced folks around here that will know more about this than I do so any views Welcome.
    Thanks.
    Lee
    nebulonN marcusquinnM timconsidineT 3 Replies Last reply
    • L LeeW
      Thanks.
      Lee
      @leew the physical location as such only matters with regards to the ping from the client location to the server location. Given that the distance as such from UK to Germany is not really that huge, I would assume it is not an issue at all. To make sure, you could spin up an instance at Hetzner and DigitalOcean and just run a few ping tests to those IPs to get a sense of the difference.
      L 1 Reply Last reply
        L Offline
        L Offline
        LeeW
        @nebulon Thanks, I actually did that and to me at least the difference was nothing.
        Digital Ocean = 26ms
        Hetzner = 35ms
        To me at least, that does not appear a significant difference in terms of visitor load time.
        • L LeeW
          Hetzner = 35ms
          @leew just to add, if you wanted an eco VPS ie powered by renewables, then some are listed in my eco VPS spreadsheet here https://ud.coop/ecovps
            I guess the other reason apart from speed and price is whether you feel comfortable hosting your server in that country (rules, regulations, privacy etc).
              L Offline
              L Offline
              LeeW
              @girish All of my sites are just info blogs, a forum and a custom-built history site. They will be fine pretty much anywhere.
              Going to go with Hetzner, as I say, not a cheapskate, was willing to pay Digital Ocean $40 per month but Hetzner Cloud gets as good if not better reviews and for much less money. Seems daft not to 🙂
              murgeroM 1 Reply Last reply
              • L LeeW
                murgeroM Offline
                murgeroM Offline
                murgero
                @leew You should also look into OVH - Get yourself dedicated hardware for similar prices (like with kimsufi for example, an OVH reseller)
                https://urgero.org
                • humptyH Offline
                  humptyH Offline
                  humpty
                  I switched this week from DO to Contabo and my initial concern was that Contabo would be overselling their VPS's and I would end up with a slow server. I'm glad to report that my VPS M NVME server is much "snappier" than it was with DigitalOcean. I was on the 2vCPU/4GB RAM DO plan (SSD) so it's not really a fair comparison (SSD vs NVME).
                  Unfortunately, my Contabo VPS had some downtime today (~5 mins) and support replied to my email within 1 min (literally). The server was back up by the time I replied back. I've been with DO (through a managed host and then as a direct customer) for over 8 years and I regret not exploring other options during that time. Not that I have anything bad to say about DO, it's just that there are other amazing hosts out there. HTH.
                  • humptyH humpty
                    @humptydumpty Indeed, it's great to see competition here for small business and personal use. Especially support and pricing are very competitive these days with the smaller VPS providers. I feel many people fall for the "big cloud" (aws/azure/gcs) trap and really struggle with their interfaces and complexity.
                    We actually use a variety of providers - DO, Linode, Ionos, Hetzner, Netcup and honestly I can't think of anything bad about any of them.
                      @girish said in How much does VPS location matter?:
                      AFAIK out of that list only Hetzner and Netcup run on 100% renewable energy. Given the urgency and serverity of the climate (and ecological) emergency I'd suggest that any server not 100% powered by renewables is in fact very bad 😛
                      (I also don't really like the fact they are all run for private profit which ultimately means they worsen inequality which is bad for everyone, but that's a whole other point/ subject 😉 bring on servers.coop! although that's still in very early days)
                      • humptyH Offline
                        humptyH Offline
                        humpty
                        I may have spoke positively about Contabo way too soon. My VPS was down again today for 5-8 mins and I received the same reply (damn copy/paste) when I asked as to what the cause is.
                        Unfortunately we experienced some technical difficulties with the Host-Server-System
                        In plain English, what the heck is that?
                        • humptyH humpty
                          murgeroM Offline
                          murgeroM Offline
                          murgero
                          wrote on last edited by murgero
                          @humptydumpty Essentially - The host server that runs all the different VMs went down. (or some other technical issue.)
                          Little diagram for explanation: The VM part is your VPS. One host server (host machine, server host, etc) can run many VMs (VPS) under itself - If the host has an issue, depending on the issue, the VM will experience it as well.
                          https://urgero.org
                          humptyH 1 Reply Last reply
                          • murgeroM murgero
                            humptyH Offline
                            humptyH Offline
                            humpty
                            @murgero Interesting. It has happened two days in a row now. That can't be good. Thanks for the explanation!
                            • L LeeW
                              Thanks.
                              Lee
                              marcusquinnM Online
                              marcusquinnM Online
                              @leew Using Hetzner from the UK, Jersey actually. It's super-fast, you really won't notice any difference for any hosting within about 3h of timezone in either direction. My recommendation; give it a go, I don't think you'll have any issues or regrest.
                              RoundHouse1924R 1 Reply Last reply
                              • L LeeW
                                Thanks.
                                Lee
                                timconsidineT Offline
                                @leew I run my UK-focussed Cloudron instance from a NetCup server in Germany, and I see no issues whatsoever in terms of performance vs a Digital Ocean or Linode London server.
                                Not a technical metrics-based response, just a user-experience perspective. Hope it helps.
                                • marcusquinnM marcusquinn
                                  RoundHouse1924R Offline
                                  RoundHouse1924
                                  @marcusquinn said in How much does VPS location matter?:
                                  Distance surely, not timezones --- unless you are talking only in east<> west terms.
                                  Bet you didn't intend to include South Africa!
                                  Self-hoster with Cloudron, Hetzner, Exoscale, Porkbun & Gandi
                                  • RoundHouse1924R RoundHouse1924
                                    marcusquinnM Online
                                    marcusquinnM Online
                                    @roundhouse1924 True. Also bear in mind EU hosting keeps your GDPR obligations simpler.
                                      L Offline
                                      L Offline
                                      LeeW
                                      @timconsidine That's very useful, thanks.
                                      • ElianaW39777620E Offline
                                        ElianaW39777620
                                        Do not think the geolocation matters with a Virtual private server(VPS). All you need is a quick, consistent, and smooth internet connection in VPS. A client likewise must have a decent Internet connection. I had VPS for ircd and I used to give shell access, there was no issue with that. The exhibition on applications was smooth and acceptable. Is it true that you are encountering any issues on the VPS you have or purchased?
                                        • ElianaW39777620E ElianaW39777620
                                          marcusquinnM Online
                                          marcusquinnM Online
                                          @elianaw39777620 A.I. bot 👋
