  2. Nextcloud
  3. Nextcloud Talk not connecting calls
nextcloud talk
30 Posts 15 Posters 21.4k Views 16 Watching
  • 32463
    32463
    3246
    Hi all,
    I finally got around to trying Nextcloud talk and while it appears to work fine when I try to connect with Cloudron users outside of my local network it fails.
    1. Both Cloudron users login to Nextcloud Talk (one via web and one via iOS app)
    2. Both users can chat and share
    3. Either user can initiate a new call and the other tries to join
    4. The joining times out
    What am I doing wrong and where can I find more documentation about getting Talk working with Cloudron for calls with WAN users?
    πŸ‘‰ Find our more www.bebraver.online
    doodlemania2D necrevistonnezrN 2 Replies Last reply
    • 32463 3246
      Hi all,
      doodlemania2D
      doodlemania2D
      doodlemania2
      @3246 This is likely due to firewalls and NATs from you and your peer. The default installation will require you to add at least a TURN server and, sometimes, a high performance backend. The cloudron turn server works well for getting through NATS.
      If you're interested, I offer a TURN and high performance backend service - see https://www.thedoodleproject.com
      I 1 Reply Last reply
      • 32463 3246
        Hi all,
        necrevistonnezrN
        necrevistonnezrN
        @3246 See for opened ports: https://docs.cloudron.io/security/ , β€žInbound Portsβ€œ
        32463 1 Reply Last reply
          32463
          32463
          3246
          @necrevistonnezr thanks, I can see the ports are open and when I try to connect with somebody outside of the network, both of us get the message that the call could not be connected 😒
          Ref. 3478, 5349, 50000 - 51000
          • 32463 3246
            32463
            32463
            3246
            When I use an external TURN server, it works.
            I followed this guide to set it up on DO using Ubuntu 18.04 LTS: https://www.netways.de/blog/2017/08/16/setting-up-a-turn-server-for-nextcloud-video-calls/
            micmcM 1 Reply Last reply
            • 32463 3246
              micmcM
              micmcM
              micmc
              @3246 Wow thankfully it works with external TURN, however it's pretty odd that it doesn't work with the Cloudron one. Apparently, there seems to be something that needs to be looked at more closely.
              (coming soon...)
              • micmcM micmc
                @micmc unfortunately the TURN server on Cloudron cannot run on port 443, which is the most reliable one for webrtc, however nginx is already running there. There is some way to split traffic in nginx, but that is not part of the open source version, it needs some streams feature. So we had to fallback to other ports, which may or may not be blocked by a network. We may have to provide a feature to select which TURN server should be used for apps, internal or external, similar to how we deal with email sending.
                robiR micmcM 32463 3 Replies Last reply
                  wrote on last edited by robi
                  @nebulon adding stream support is done by enabling the module config.
                  See:
                  https://jitsi.github.io/handbook/docs/devops-guide/turn
                  Hence you can rev/fwd proxy anything as long as you can pass in the servername for nginx to pivot on.
                  FYI the stream_core_module is included in Ubuntu enginx-core packages.
                  P.S. It would be useful for @staff to be aware of the other modules for mail and other services that are available for multi-cloudron functionality.
                    See:
                    32463
                    32463
                    3246
                    wrote on last edited by 3246
                    I'm playing with https://markus-blog.de/index.php/2020/11/20/how-to-run-nextcloud-talk-high-performance-backend-with-stun-turnserver-on-ubuntu-with-docker-compose/ on a Scaleway VM now to see how it works. It would be ace to get Cloudron's proxy to be able to proxy to the TURN/STUN server. Maybe my set up is too complicated (double NAT) and it works more smoothly to run Cloudron on a dedicated VM in a data centre somewhere πŸ˜•
                      micmcM
                      micmcM
                      micmc
                      wrote on last edited by micmc
                      @nebulon said in Nextcloud Talk not connecting calls:
                      Yeah, true I always forget this 'limitation' that TURN needs to run on port 443.
                      While being at it that would be a great solution, and for several apps at the same time. +1 πŸ™‚
                      (coming soon...)
                        32463
                        32463
                        3246
                        @nebulon I just noticed that my custom TURN settings are being overwritten when the app is updated 😒
                        stun_server
                        turn_server
                        TURN server schemes
                        turn_secret
                        Looks like signaling_secret is not affected.
                        I assume this is the expected behaviour but as a user who customises this, I would like my own settings to be honored, please πŸ˜‰
                        • micmcM micmc
                          32463
                          32463
                          3246
                          @micmc said in Nextcloud Talk not connecting calls:
                          Where does this come from or where you being sarcastic? (sorry, my translator is not enabled today) πŸ™‚
                          I run my own TURN and STUN servers on port 3478. Maybe I am misunderstanding?
                          nebulonN E 2 Replies Last reply
                          • 32463 3246
                            @3246 this is not a real requirement but just depends on which network the clients are on. Some public wifis for example would block most ports besides the common ones. TURN on 443 is just a safe bet, since 443 is basically always open.
                            • 32463 3246
                              E
                              E
                              eganonoa
                              @3246 @girish mentioned public wifis. I think biggest reason for setting up turn on 443 is that very many (most?) academic and corporate IT systems block everything but 443 for ordinary users. So you'll never get a good connection if you have users accessing the internet there.
                              Cloudron does indeed overwrite the turn server setting in Nextcloud upon reboot/update of the app. Thankfully with Nextcoud you don't need to reboot to add the turnsever back in. So adding it works.
                              Sadly that's not the case with other apps - notably matrix - which means those apps will be limited in their videoconferencing capability until the ability to add an external turnserver is added to cloudron.
                              @girish from my perspective I don't think you need a per-app choice there. Just a global option which turnserver to use across apps. My sense is that people who need an external turnserver for one app (because of users in an academic/corporate setting or using Cloudflare, etc) will need it for them all.
                              • list item
                              • E eganonoa
                                • list item
                                32463
                                32463
                                3246
                                @girish @nebulon is there a way for me to hardcode my own TURN server / HPB? I have to manually check and update three Nextcloud sites every day, which is getting a bit tedious 😭
                                Pretty please 🐱
                                • 32463 3246
                                  Pretty please 🐱
                                  @3246 this is coming in 7.2 - https://forum.cloudron.io/topic/6655/what-s-coming-in-7-2 (the last bullet point)
                                  32463 D 2 Replies Last reply
                                    32463
                                    32463
                                    3246
                                    @girish said in Nextcloud Talk not connecting calls:
                                    Amazing! Thank you πŸ˜„
                                    • doodlemania2D doodlemania2
                                      I
                                      I
                                      Innky
                                      @doodlemania2
                                      1. Do I need to install the turn server on the same server I installed the nextcloud
                                      Or a different server?
                                      My nextcloud works fine just that I can not call users on a different network.
                                      How do I do this right, for I call users who are not on the same networks?
                                      Thank you
                                        D
                                        D
                                        dmikolaj
                                        @girish where are we at with this solution in 7.2? My nextcloud talk won't work with the default turn settings, it only works when all the devices in the call are on the same local network. looks like my preconfigured by cloudron turn settings in nextcloud are on port 3478.
                                        also if i overwrite my turn settings, where in your documentation are the settings located so i can restore to the cloudron defaults?
                                        • J
                                          @dmikolaj is this spam?
                                          D 1 Reply Last reply
