  3. Evernote alternative
23 Posts 10 Posters 12.0k Views 9 Watching
    A Former User
    What do you think is the best Evernote alternative that Cloudron offers?
    I have only had bad experiences with Nextcloud updates, so I would rather not use that. It would also be nice if I could share the documents with a team, but it's not a must-have.
    L 1 Reply Last reply
      There's always the awesome selfhosted list to dig in further - https://github.com/awesome-selfhosted/awesome-selfhosted#note-taking--editors
      • jdaviescoatesJ
        Super Fan
        and
        https://selfhosted.libhunt.com/categories/1702-note-taking-and-editors
        and
        https://alternativeto.net/software/evernote/
          Go to the Cloudron appstore and select the "Notes" category for the available options.
          Personally using HedgeDoc for team collab notes which then go into Joplin.
          ? 2 Replies Last reply
          • ruihildtR
            ruihildtR
            ruihildt
            I've been happy with trilium for personal use.
            timconsidineT ? 2 Replies Last reply
            • ruihildtR ruihildt
              @ruihildt said in Evernote alternative:
              @ruihildt what do you do about mobile client like on a phone ?
              ruihildtR 1 Reply Last reply
                ruihildtR
                ruihildtR
                ruihildt
                @timconsidine I don't use it much on mobile. But otherwise, pin it and use it as a webapp. (I'm also using the webapp on desktop actually through Ferdium)
                  @ruihildt 👍
                    A Former User
                      A Former User
                      @ruihildt Does trilium handle PDF?
                        A Former User
                        @robi Joplin seems to be the nearest option. Thanks for your answer.
                        • ? A Former User
                          marcusquinnM
                          marcusquinnM
                          CA Maintainer Super Fan
                          @bushido 👍 for Joplin, browser extensions are also likely the most similar to Evernote's.
                          • ? A Former User
                            CA Maintainer
                            @bushido Odoo Community Edition has a Notes module:
                            https://www.odoo.com/app/notes
                            Much work on supporting Odoo (and possibly flectra) has already taken place and there is an App Request for this powerful tool.
                            • ? A Former User
                              ruihildtR
                              ruihildtR
                              ruihildt
                              @bushido There's apparently a PDF reader, but I've not used it.
                              There's also a browser extension: https://github.com/zadam/trilium/wiki/Web-clipper
                              • P
                                P
                                privsec
                                Super Fan
                                https://www.reddit.com/r/privacy/comments/x3eeyt/notesnook_a_private_and_end_to_end_encrypted/
                                  A Former User
                                  @bushido said in Evernote alternative:
                                  Thanks everyone for your hints. My question was for an Evernote alternative that Cloudron offers
                                  ei8fdbE marcusquinnM 2 Replies Last reply
                                  • ? A Former User
                                    ei8fdbE
                                    ei8fdbE
                                    ei8fdb
                                    @bushido I've been using Joplin (install the client on your device/s and then synch via the Joplin server available on Cloudron) as a replacement for Evernote for personal and work usage for the past 1 year and it is the closest alternative for me. The only area is lacks in comparison to Evernote is in note sharing, but it works well.
                                    ? 1 Reply Last reply
                                    • ? A Former User
                                      marcusquinnM
                                      marcusquinnM
                                      @bushido LogSeq is worth a look too, and a good example of FOSS with an Open Collective for contributions.
                                      • https://forum.cloudron.io/topic/4718/logseq-privacy-first-open-source-knowledge-sharing-and-management-platform-like-notion-roam-obsidian
                                      • ei8fdbE ei8fdb
                                        A Former User
                                        @ei8fdb Thanks for your recommendation.
                                        • marcusquinnM marcusquinn
                                          A Former User
                                          @marcusquinn said in Evernote alternative:
                                          Thanks. Does it handle PDF files?
                                          timconsidineT marcusquinnM 2 Replies Last reply
