  3. PTR problem between Linode & Mastadon
linodeptr
31 Posts 6 Posters 7.8k Views 6 Watching
  • scookeS scooke
    @DeBossNow Leave Linode. Why hit your head against a wall you know is there???
    And apologize.
    D
    D
    DeBossNow
    @scooke This is such a minor problem.
    The solution is easier to leave Cloudron, proportionately, than leave the Linode hosting over such a minuscule problem.
    Just the PTR check. It bothers me to see it when it could be resolved by revising the PTR script at Cloudron to understand that it must append the base domain to the subdomain DNS entries it finds. Because Linode JUST saves the naked prefix in that field.
    The Cloudron PTR check a couple of years ago was reported by more than me in the forum as persisting in this error that could not be changed at Linode. They just do not save anything but the individual prefix for each subdomain DNS reverse entry.
    All subdomains in the A/AAAA records at linode are saved by prefix only --
    my (not my.currentdomain.de)
    mail (not mail.currentdomain.de)
    • D DeBossNow
      @ccfu l understand the interface problem.
      I did not start in this stuff a week ago.
      I am telling you that the PTR check is what does not understand, so to speak, the "Interface problem".
      I do not have access to the Cloudron PTR check script to modify it for what it finds when it checks the server configuration at linodes.
      It is an inteface mismatch not with ME but with the internals of the script. It does not find the literal string "my.currentdomain.de" -- it obviously ONLY finds "currentdomain.de". There is an adjacent record at Linode that should contain the value "my.currentdomain.de" just as the MX record contains.
      But I cannot edit, I cannot add that DNS reverse lookup value as "my.currentdomain.de". And, obviously Linode does not read out that full prefix with base domain name to the Cloudron PTR script.
      I thought this would be simple. I am done. I thank you for all your help, everyone.
      C
      C
      ccfu
      wrote on last edited by ccfu
      #22
      @DeBossNow
      It is simple, but unfortunately you don't seem to be willing to understand the way certain things work and where you need to set what. Also, you ignore what people tell you and just repeat the same incorrect information (for example that Linode just saves a prefix (sic), but you say you understand the interface problem).
      The PTR check does exactly that - it checks the PTR record for the domain that is set as the mailserver location and if this doesn't match then the check will logically fail. There is nothing wrong with the check script.
      What domain is set as the mailserver location in Cloudron?
      What domain is set in your PTR record?
      D 1 Reply Last reply
      • scookeS
        scookeS
        scooke
        It doesn't even make sense - OP wants Cloudron's script to check for a SINGLE WORD PTR record, "my".
        I am blocking this user. Even though they've been here a fair amount of time, this is just nonsense posting which is wasting everyone's time who tries to help.
        bye!
        • C ccfu
          @DeBossNow
          D
          D
          DeBossNow
          @ccfu Thank you for your help.
          I understand that you have a lot on your plate, so I appreciate your expertise.
          But, my willingness to help or cooperate is not necessarily reflected by failing to understand you.
          What you have just asked me I have included as Copy and Paste directly from both my Linode server and from my Cloudron dashboard -- only obscuring IP and Domain name.
          My Cloudron Dashboard
          Email configuration
          The PTR record is set by your VPS provider and not by your DNS provider.
          Hostname: xx.xx.xxx.xxx
          Record type: PTR
          Expected value: my.currentdomain.de
          Current value: currentdomain.de
          **At my Linode dashboard I see that Cloudron has set the
          MX Record to be
          Mail Server Preference Subdomain
          my.currentdomain.de 10
          But i literally can not get this same value saved as a PTR record.
          Linode server Configuration --
          A/AAAA Record
          Hostname IP Address
          currentdomain.de xx.xx.xxx.xxx
          my xx.xx.xxx.xx
          Cloudron PTR check says that it wants to find a DNS record that reads as
          my.currentdomain.de IP Public xx.xx.xxx.xxx
          But all Cloudron reports is finding my base domain name. currentdomain.de
          The next entry that the PTR script should find is
          but when I ADDED that subdomain record ...
          writing
          my.currentdomain.de
          IP xx.xx.xxx.xxx
          It always saves just as
          my IP xx.xx.xxx.xxx
          Every subdomain prefix with period. and full domain name that I add will only save in the field as the prefix.
          The Edit function after the fact does not make any difference either.
          BrutalBirdieB C 2 Replies Last reply
          • D DeBossNow
            Email configuration
            Record type: PTR
            MX Record to be
            A/AAAA Record
            Hostname IP Address
            my xx.xx.xxx.xx
            writing
            my.currentdomain.de
            IP xx.xx.xxx.xxx
            my IP xx.xx.xxx.xxx
            BrutalBirdieB
            BrutalBirdieB
            @DeBossNow
            The PTR record can not be set in the same web interface as the normal DNS settings for MX A AAAA TXT @ records.
            It really, really, REALLY reads like you are in the wrong management web interface!
            Please read and follow the official Linode guide and set the correct value.
            https://www.linode.com/docs/products/compute/compute-instances/guides/configure-rdns/#setting-reverse-dns
            And still, please share your real domain so I can validate the DNS settings, this could save us all so much time and pain.
            • D DeBossNow
              Email configuration
              Record type: PTR
              MX Record to be
              A/AAAA Record
              Hostname IP Address
              my xx.xx.xxx.xx
              writing
              my.currentdomain.de
              IP xx.xx.xxx.xxx
              my IP xx.xx.xxx.xxx
              C
              C
              ccfu
              #26
              @DeBossNow
              OK, let's try one last time to get this resolved for you:
              @DeBossNow said in PTR problem between Linode & Mastadon:
              Email configuration
              Record type: PTR
              This means that your server's PTR record is currentdomain.de but the mailserver location is my.currentdomain.de. That is a mismatch, so the check fails.
              MX Record to be
              This is irrelvant and has nothing to do with outgoping mail or the PTR check. I also doubt that it was set by Cloudron, more likely by Linode.
              Why not? I suspect because you are trying to do it in the wrong place.
              A/AAAA Record
              Hostname IP Address
              my xx.xx.xxx.xx
              That's fine, but you also need the PTR record to be set to this.
              No, that is not how it works. There is only one PTR entry for the server.
              writing
              my.currentdomain.de
              IP xx.xx.xxx.xxx
              my IP xx.xx.xxx.xxx
              That is correct and not the problem here.
              What domain is set as the mailserver location in Cloudron on the mail settings page? If it is my.currentdomain.de change it to currentdomain.de.
              • C ccfu
                @DeBossNow
                Email configuration
                Record type: PTR
                MX Record to be
                A/AAAA Record
                Hostname IP Address
                my xx.xx.xxx.xx
                writing
                my.currentdomain.de
                IP xx.xx.xxx.xxx
                my IP xx.xx.xxx.xxx
                D
                D
                DeBossNow
                @ccfu I had no MX record when I set up the new server at Linode yesterday.
                After I chose to use the Default Cloudron smtp server THEN Cloudron asked for permission to go setup the MX Server.
                When I returned to the linode dashboard i saw the updates that Cloudron did. The MX Email server was set to the same address as the Default Cloudron Login Panel url for this domain.
                Hence, the MX Server said ... my.currentdomain.de was the address for my Email server. I did not choose the my. prefix for this.
                Nevertheless, I CHANGED THE MX server at Linode from "my.currentdomain.de" to the base domain url "mycurrentdomain.de" for my Mastadon installed website.
                I waited now for 10 minutes, refreshing my Email status report every minute. PTR error still showed that it was expecting "my.curentdomain.de".
                But then I re-enabled the Cloudron email server to RECEIVE Emails at my domain instead of just being able to Send emails from his domain.
                Then up popped this --
                When I clicked the Enable button within a minute back at Linode Cloudron had RESET my MX Record to --
                my.currentdomain.de This is the Cloudron Email setup default.
                So, the PTR record error at cloudron persists
                RESETTING the MX Record as you suggest does not get rid of this error.
                I CAN go back to Linode and OVERWRITE what the Cloudron Email (enabled Incoming email reception, too) MX Server has saved ... my.currentdomain.de .... but it seems like that will mess up this Incoming email service, since it is Cloudron that specified this.
                D C 2 Replies Last reply
                • D DeBossNow
                  D
                  D
                  DeBossNow
                  I mistyped this ... I changed the MX Server at linode to the base domain "currentdomain.de"
                  • D DeBossNow
                    C
                    C
                    ccfu
                    @DeBossNow
                    Please ignore the MX record. As I have written several times now, this has absolutely nothing to do with the PTR check which only concerns outgoing email.
                    Once again: Go to the email settings page in your Cloudron dashboard and check the domain that is entered as the mailserver location:
                    • C ccfu
                      @DeBossNow
                      D
                      D
                      DeBossNow
                      @ccfu I have CHANGED the Email Server domain that Cloudron set when I enabled Incoming Email reception.
                      I changed it Back to my base domain, removing the my prefix.
                      And then I Reset the DNS to update my Linode server.
                      At first the only error was an SPF but it resolved a few minutes later.
                      I have Green Lights again.
                      I am trying to resolve the communication frustration, though. I went through all the standard steps of Install.
                      Setting the Email server to enable Incoming email at my domain DID set the MX server at Linode to use "my.currentdomain.de" I never chose this prefix and never entered it either at my Linode server configuration or in my Cloudron panel.
                      Several times the responses I have gotten was that I must have made up this configuration. I also read several times in our communications that it "has nothing to do with your MX Server", yet also saying that it was the COMPARISON between the mismatching MX Server value and the base url. So, both things can not be true. The PTR errror DID have everything to do with the MX Server value.
                      In our communications I made it clear that for me to change or modify the MX Server value I was going to my Linode Server account dashboard. Especially with the caveat that the PTR value had to be set at my Linode account.
                      Yet, you were evidently referring to going to the Cloudron dashboard and
                      1. to go first to the right side Admin panel to bring up Email Settings and then
                      2. click on Mail server location and the checkbox pencil.
                      3. Make the change there in the Edit function ... removing my. and saving there.
                      4. And then I had to go back out of the Owner admin window and
                      5. to the other Cloudron Email Configuration Status control and hit REDO DNS SETUP.
                      So now I know by trial and error that to fix the PTR error I reported that I must REJECT the default Cloudron setup which installed the MX Server setting at my Linodes volume with a prefix my.
                      That I must go through the above steps in my Cloudron Admin panel to finally fix the error.
                      RESOLVED. Thank you for putting up with all of this!
                      C 1 Reply Last reply
                      • D DeBossNow
                        C
                        C
                        ccfu
                        #31
                        @DeBossNow
                        I am glad you got it resolved, but just to clarify:
                        The MX record is for incoming email. It needs to be set to any domain name that resolves to your server, i.e. has a valid A record. If both my.currentdoain.de and currentdomain.de resolve then you can use either for incoming mail. The mismatch was not with the MX record but between the mailserver domain set in Cloudron and the PTR record of the server. At no point did I or anyone else tell you to change the MX record, and no, the PTR error had nothing to with the MX record. I can therefore only assume that you interpreted MX as being something it is not.
                        For outgoing mail you need a valid PTR record that matches the mailserver domain. You also need a valid SPF record and a valid DKIM entry.
                        Because you set up Cloudron via the Linode app you have presumably told Cloudron to use Linode DNS, which is why it is updating / overriding certain settings. If you do not want it to do that you need to set DNS to manual for the resepctive domain(s).
                        The bottom line is: The PTR record and mailserver domain have to match. Where you make the changes depends solely on the domain you want to use for email, i.e. where the entry needed updating to match.
                        Btw, I stated every time that you needed to check / update the mail domain in Cloudron, not in the Linode dashboard.
