  3. Calibre (& Calibre web?)
43 Posts 10 Posters 26.1k Views 12 Watching
  • yusfY
    yusfY
    yusf
    Works pretty good! LDAP integration will ace it! 🎴
    • ei8fdbE
      ei8fdbE
      ei8fdb
      I've read this thread but wanted to ask - is there a procedure to follow for this installation? I'd like to try it.
        @ultraviolet I tried to move the app package forward. Can you tell me how those database files are created (and why are they needed?). Meaning the files here - https://github.com/euanmcgregor/calibre-web-cloudron/tree/master/Library
        ultravioletU 1 Reply Last reply
          @ei8fdb I put a small tutorial here - https://forum.cloudron.io/topic/3102/building-custom-packages . Feel free to ask questions there.
            ultravioletU
            ultravioletU
            ultraviolet
            @girish Yes they are needed that is the base database for calibre, they are copied to the app/data on build (if I recall correctly)
              @ultraviolet I see but how did you generate them or create them? Are they provided by the upstream project?
                ultravioletU
                ultravioletU
                ultraviolet
                @girish ah with you. No it needs to be generated by the calibre project it is an empty database created that the web app uses to connect to. I created it as I would then need to install calibre into the app container then use the api to generate the empty db then remove calibre. Seemed a waste of time so I created a blank one for the purpose of ease.
                  Got to hack on the app this weekend. Still have to figure how to automate the settings but I wanted to ask how this integrates with mobile apps. It seems to me that this is done via the calibre content server (and not calibre web). I think it would not be very useful if we just had calibre web but no way to access the books from the mobile apps. I think what this means is that I have to set up the app so that the content server is also running (and authenticates via LDAP or something).
                  Am I correct about this?
                    Super Fan
                    @girish I don't know, but I'd still find it useful even if I couldn't use mobile apps (my phone is full up and has no space for any more apps anyway - it's so annoying I can't delete all the Google apps I never user, once this phone dies I'm definitely going to get a 2nd hand phone that will run https://e.foundation/ or https://lineageos.org/ )
                    • T
                      T
                      thetomester13
                      @girish the combination of Calibre and Calibre-web is quite tricky. That being said, there are plenty of apps that can read from Calibre-web's OPDS server. I personally use MapleRead SE on iOS, but any app that supports OPDS can plug into Calibre-web's server.
                      Also, I could be wrong here, but I believe Calibre doesn't support LDAP whereas Calibre-web does.
                        @thetomester13 said in Calibre (& Calibre web?):
                        OPDS
                        Ah, thanks for this note. This is what I was missing. I was wondering how to get books out of the app for mobile use and this seems to be it.
                        @jdaviescoates I also managed to figure out how to automate the LDAP parts, so I will get it published soonish.
                          OPDS
                          Super Fan
                          @girish said in Calibre (& Calibre web?):
                          Woohoo! 😄
                          • mehdiM
                            mehdiM
                            mehdi
                            So, anyone know if the desktop apps can synchronize with the web app ? I have a quite large Calibre library locally, I'd appreciate uploading it and keeping it in sync
                            T 1 Reply Last reply
                            • mehdiM mehdi
                              T
                              T
                              thetomester13
                              @mehdi Yes, Calibre is the 'backend' for Calibre-web. If you manage to upload your local Calibre to this Calibre, then Calibre-web should have it all synced up for you. I managed to do this upgrade before (with a relatively small library). I wonder if I can dig up the instructions somewhere...
                              • jdaviescoatesJ
                                Super Fan
                                @mehdi from a quick search around it also seems one possible option (which I think I might try once we've got Calibre-web in Cloudron) is to store your Calibre library in a Nextcloud folder and then connect/ sync both the desktop Calibre and Calibre-web to that.
                                  Alright, almost there. There's a few bugs I have to report upstream and learn some python along the way to get those fixed.
                                    I hope there's a dark mode!
                                    yusfY 1 Reply Last reply
                                      I have opened https://github.com/janeczku/calibre-web/issues/1656 for a start.
                                        I have pushed this to unstable now. Still some work to be done, hopefully should get done next week.
                                          T
                                          T
                                          thetomester13
                                          @girish 👏 thanks! This is definitely something I've been wanting for a while. I'll play around with this soon and try and post instructions on migrating from a manual installation (@ultraviolet 's package) to this one.
