  3. Calibre (& Calibre web?)
43 Posts 10 Posters 24.8k Views 12 Watching
  • T thetomester13
    @girish 👏 thanks! This is definitely something I've been wanting for a while. I'll play around with this soon and try and post instructions on migrating from a manual installation (@ultraviolet 's package) to this one.
    @thetomester13 yes, I want to move in all my books as well. The app itself works well , just the integration points need to be ironed out. Also, let me know if the OPDS works for you.
    T 1 Reply Last reply
      T
      T
      thetomester13
      @girish Ok, got it up and running! I'm not seeing LDAP working, I'm only able to logon using the admin/admin123 credentials, but I know you mentioned this as an issue. I am able to get the OPDS link to work though. I'm using the MapleRead SE iOS app, and the link should look like https://calibre.my.cloudron/opds.
      In the way of migrating things over from a manual instance to this instance:
      1. I went to the Terminal of the old instance and hit 'Download' and downloaded the /app/data/Library directory
      2. In your new instance, go to the File Manager. Upload this Library folder. Change permissions to the folder from 'root' to 'cloudron'.
      3. In your new Calibre instance, go to the 'Admin' view page. Under 'Basic Configuration' => 'Library Configuration' put /app/data/Library and hit 'save'.
      4. Back in the Admin view page, hit 'Reconnect to Calibre DB'.
      5. If you go to your Calibre-web home you should now see your library!
        I hope there's a dark mode!
        yusfY
        yusfY
        yusf
        @robi There's this caliBlur thing, but I wouldn't necessarily trust its longevity.
