  3. OpenSlides - digital motion and assembly system
47 Posts 13 Posters 25.0k Views 15 Watching
    OpenSlides is the all-in-one solution for running your plenary meetings and conferences. Show the current presentation on the main screen, while you show the agenda, motions, list of speakers on others. Working on elections and documents in parallel with all participants. Web-based and always up-to-date.
    https://openslides.com/en
    https://github.com/OpenSlides/OpenSlides
    29
      @girish oooh, nice find! I know some conference organisers who would definitely be interested in this!
      • jimcavoliJ
        jimcavoliJ
        jimcavoli
        Not only is this an awesome find and great-looking app (wish I knew of this in May), but something I have a distinct use for. As such, I've begun an initial packaging effort.
        • jimcavoliJ jimcavoli
          @jimcavoli excellent! Hopefully before long we'll be able to have large gatherings again! (not holding my breath though - here in the we UK can't even sort a decent test and trace system despite having blown £12 billion on one!)
          • jimcavoliJ
            jimcavoliJ
            jimcavoli
            Happy to announce that this is running on my testbed server presently, and fairly responsively after a slight memory bump (256M just isn't enough to keep all the workers alive, even for one user). Going to try toggling on some of the other optional bits, but then this should be near ready for the unstable channel. User management is all in-app for better or worse, but that's an upstream limitation (only supports SAML optionally to act as an external IdP).
              @jimcavoli Very cool. Where is the repo? Also, does the app work well?
              jimcavoliJ 1 Reply Last reply
                jimcavoliJ
                jimcavoliJ
                jimcavoli
                @girish Works really well; repo forthcoming. I'm still working locally. The main trick just seems to be setting a reasonable floor for the memory limit; I think it's going to be 768M or so as a minimum to ensure the workers all stay up and responsive for a reasonable handful of connections. It makes heavy use of web sockets so it's a hair resource intensive, but given the nature of it, it shouldn't be a big deal for folks to deploy, test, scale up temporarily for an event, and scale back or remove after it's done. The app is rather specifically designed that each installation is one event, something they may change in the future, but for now, really makes running it on Cloudron so much more sensible than any other methodology. (their documentation on how to run it is garbage, basically though; really pushing the hosted version with the dearth of docs)
                I'll just finish a little more testing, especially around file uploads and media handling, tonight, and that repo will be linked here following.
                • jimcavoliJ
                  jimcavoliJ
                  jimcavoli
                  Repo with initial packaging: https://git.cloudron.io/jimcavoli/openslides-app
                  I'd regard this as pretty ready to go at this point - all packaging choices were in line with the production configurations recommended by the project. I've tested pretty much everything except SAML manually. User management is independent for the time being as described previously. Also notable is that after some testing, I found 524288000 left enough headroom as a memoryLimit floor that the app was usable without constant restarts for light duty (not going to service a 1000 person assembly, probably, but fine for prepping an event and then deciding how to scale up from there). Other notes are in the README of the packaging repo. Also recommend building with buildkit turned on if you don't normally - the JS compilation takes a short eternity, but the Dockerfile takes pretty good advantage of buildkit multistage builds for parallelizing as well as limiting bloat in the final container.
                    @jimcavoli awesome, thanks! will take a look next week.
                    Marked this as wip.
                      Marked this as wip.
                      jimcavoliJ
                      jimcavoliJ
                      jimcavoli
                      @girish Just a bump on this - figure it got lost in the 6.0-releasing shuffle. No huge deal, but hope it can still make unstable this year 🙂
                        @jimcavoli Not lost 🙂 It's marked as https://forum.cloudron.io/tags/wip . But yes, now that we got Cloudron 6 out of the day (save the announcements), we will have time to push these out.
                          The build currently fails
                          Step 6/32 : RUN mkdir -p /app/{src,build} &&     curl -L https://github.com/OpenSlides/OpenSlides/archive/${OPENSLIDES_VERSION}.tar.gz | tar zxf - --strip-components 1 -C /app/src &&     chown -R cloudron:cloudron /app/src
                           ---> Running in cb29f0b4fa6c
                            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                           Dload  Upload   Total   Spent    Left  Speed
                          100     9  100     9    0     0    121      0 --:--:-- --:--:-- --:--:--   121
                          gzip: stdin: not in gzip format
                          tar: Child returned status 1
                          tar: Error is not recoverable: exiting now
                          The command '/bin/bash -c mkdir -p /app/{src,build} &&     curl -L https://github.com/OpenSlides/OpenSlides/archive/${OPENSLIDES_VERSION}.tar.gz | tar zxf - --strip-components 1 -C /app/src &&     chown -R cloudron:cloudron /app/src' returned a non-zero code: 2
                          Failed to build app. See log output above.
                            Oh, it seems the ARG has to be added for each build stage (don't have much experience with these multi-stage builds).
                              Works after that moving the VERSION arg down. Will get it published tomorrow.
                                jimcavoliJ
                                jimcavoliJ
                                jimcavoli
                                wrote on last edited by jimcavoli
                                @girish Weird. FWIW, I run with DOCKER_BUILDKIT=1 on all the time - https://docs.docker.com/develop/develop-images/build_enhancements/ for more on that particular feature. Glad you got it sorted and we can get this app out there!
                                • S
                                  S
                                  seeker
                                  What an awesome find
                                  • jimcavoliJ
                                    jimcavoliJ
                                    jimcavoli
                                    I've updated https://git.cloudron.io/jimcavoli/openslides-app for OpenSlides 3.3
                                    yusfY 1 Reply Last reply
                                      yusfY
                                      yusfY
                                      yusf
                                      @jimcavoli Oh wow, this with LDAP and large voting sessions can become a breeze. 😋
                                      • yusfY yusf
                                        jimcavoliJ
                                        jimcavoliJ
                                        jimcavoli
                                        @yusf I agree. Unfortunately it only supports SAML for SSO so far. Could send a feature request upstream. I've also got a partially-implemented packaging of the Shibboleth IdP for Cloudron, but that's a little stalled while I work out how to deal with some of its idiosyncrasies
                                        • jimcavoliJ
                                          jimcavoliJ
                                          jimcavoli
                                          @girish Any updates on progress to app store for this one?
                                          girishG 2 Replies Last reply
