  3. Need help with GitLab (git.cloudron.io)
11 Posts 5 Posters 5.0k Views 5 Watching
  • eriktadE Offline
    eriktadE Offline
    eriktad
    Hi guys. I'm new to you. and I want to start the development of the application and I registered on your GitLab, please, someone can explain to me what I need to do to start, I do not have the access to create a repository, I already send an Access Request, if it is possible can you help me and explain it all, I am very grateful in advance, you have everything so arranged that I want to start working and help you.
      Hi and welcome! You can start by taking a look at our application packaging guide at https://docs.cloudron.io/custom-apps/tutorial/
      I will also grant you repo space on our GitLab.
      eriktadE 1 Reply Last reply
        eriktadE Offline
        eriktadE Offline
        eriktad
        @nebulon Thank you very much, this is my gitlab profile https://git.cloudron.io/erik
          @eriktad If you are planning to work on a general purpose app that can be published in the app store, please leave a note in the appropriate https://forum.cloudron.io/category/5/app-wishlist forum entry. And welcome on board 🙂
          LonkleL eriktadE 2 Replies Last reply
          • eriktadE eriktad
            marcusquinnM Offline
            @eriktad is one of our dev team, looking forward to getting more on-board to share the joy 🙂
              LonkleL Offline
              LonkleL Offline
              Lonkle
              @girish said in Need help with GitLab (git.cloudron.io):
              Should we move the VPN Client app (which is 100% finished now) to the App Wishlist to follow this procedure?
              • LonkleL Lonkle
                @lonk Yes, please open a new thread for the VPN client as an app request. I think we should try to get it published (the cloudron code integration can come after it's published)!
                  eriktadE Offline
                  eriktadE Offline
                  eriktad
                  @girish Yes thank you, I am. Now I try to create a Prometheus app, work in progress but can't find any doc with a health check, I am already on it and if you can help it would be great.
                  eriktadE marcusquinnM 2 Replies Last reply
                  • eriktadE eriktad
                    eriktadE Offline
                    eriktadE Offline
                    eriktad
                    @eriktad https://git.cloudron.io/erik/prometheus-app this is my repo, think it is a little bit ugly for now xd.
                    • eriktadE eriktad
                      @eriktad Maybe relevant? Depends if it uses htaccess auth or standard login?
                      https://forum.cloudron.io/topic/2166/healthcheck-for-protected-custom-node-apps
                      • marcusquinnM marcusquinn
                        eriktadE Offline
                        eriktadE Offline
                        eriktad
                        @marcusquinn Oh yes think it would be help
