  3. Issue with backups listings and saving backup config in 6.2
backupsovh
32 Posts 2 Posters 7.4k Views 2 Watching
    @d19dotca OK, sorry, I can confirm you are not imagining things. If I use OVH in dropdown it does not work. If I use it in "S3 compatible", it works. (i.e testing both with storage subdomain) This should be easy to figure out now what is different.
    d19dotcaD Offline
    d19dotcaD Offline
    d19dotca
    @girish lol, okay glad to know I'm not crazy. I am still wondering how it changed from storage to s3 as I didn't change the preset at all, it still shows OVH Object Storage, not the s3-compatible type one (though I realize they appear to use the same code in the backend).
    Dustin Dauncey
    www.d19.ca
      @d19dotca Found it! Phew.
      The storage subdomain only supports path style API whereas s3 subdomain supports subdomain style API. The path style API is already deprecated (though they have backtracked a bit on it) - https://aws.amazon.com/blogs/aws/amazon-s3-path-deprecation-plan-the-rest-of-the-story/ . So, s3 subdomain is the way to go with it's vhost based API access.
      Now, for Cloudron UI, all the named providers use vhost style. This is why storage does not work. The 'Compat' option (and minio) uses the path style for compat reasons.
      d19dotcaD 1 Reply Last reply
      • d19dotcaD d19dotca
        @d19dotca It seems that apart from trying to figure why storage magically changed to s3, we are good. I am suspecting maybe there is some UI bug. Just clicking around the UI to see if it's something obvious to reproduce.
          d19dotcaD Offline
          d19dotcaD Offline
          d19dotca
          @girish Awesome, thanks Girish! 🙂 Thanks for looking into that. Sorry for causing so much confusion, glad we got to the bottom of it though.
          Dustin Dauncey
          www.d19.ca
            d19dotcaD Offline
            d19dotcaD Offline
            d19dotca
            #25
            @girish Actually sorry one more thing I'm wondering about... if we believe the storage and s3 thing in the GUI to just be a possible GUI issue, wouldn't that mean it's in fact using storage then since that's what the 6.2 code points it to and the database points to it too? And if it's indeed using the storage endpoint then my last backup worked, so why would that work if storage isn't the right endpoint? lol Sorry just trying to wrap my head around it and make sure we've resolved it.
            Dustin Dauncey
            www.d19.ca
            girishG 2 Replies Last reply
              #26
              @d19dotca Sure. So the db in 6.2 says storage and also path style disabled. This means that when a user goes to Backups view, he will see storage but backups will fail. Also, if you go to Backups -> Configure and Click Save making no changes, you will get that XML error.
              Correct
              This, I am not so sure (and I guess cause of much confusion for us). Atleast, from my tries here, I couldn't get it work with storage endpoint with 6.2. I don't see how it can work with path style disabled. I guess one way to know this for sure is to go to the EventLog and see if any backup succeeded after the 6.2 update but before the backup config was changed? Sadly, I think we don't log backup config in the event log.
                #27
                @d19dotca Also, looking at your post here - https://forum.cloudron.io/post/27080 . Somehow you managed to get s3 in endpoint URL. I think this is why the backup succeeded. Also, to clarify, what is in the db and what is in the UI are in "sync".
                  d19dotcaD Offline
                  d19dotcaD Offline
                  d19dotca
                  #28
                  @girish said in Issue with backups listings and saving backup config in 6.2:
                  That's the thing, I didn't do that, at least not intentionally. haha. So I was about to go change to the generic s3-compatible type, but before I did that that's when I noticed the Region was empty, so I just left it as it was but set the Region and saved, then tried the backup again to see if it was successful and it was. Is it possible that saving it somehow overwrote the storage endpoint back to s3? Maybe another part of the code needs to be modified?
                  For the database, it showed the storage endpoint used earlier this morning, and when I run the same command now it shows the s3 endpoint instead. So I think maybe part of the confusion earlier was that when I saved the changes (where all I did was edit the Region from null to BHS), it overwrote it back to s3 from storage. Do you think that's possibly what happened, if you look at the code side of it?
                  Here's what the DB looks like now, but compare to this the link above where I pasted it this morning before I saved the change to fill in the Region field...
                  ubuntu@cloudron:~$ mysql -uroot -ppassword -e "SELECT * FROM box.settings WHERE name='backup_config'"
                  mysql: [Warning] Using a password on the command line interface can be insecure.
                  | name          | value        |
                  | backup_config | {"provider":"ovh-objectstorage","format":"tgz","memoryLimit":4294967296,"schedulePattern":"00 00 7,19 * * *","retentionPolicy":{"keepWithinSecs":172800},"bucket":"cloudron-backups","prefix":"","accessKeyId":"<accesskey>","secretAccessKey":"<secretkey>","endpoint":"https://s3.bhs.cloud.ovh.net","region":"bhs","signatureVersion":"v4","uploadPartSize":1073741824,"encryption":null} |
                  Dustin Dauncey
                  www.d19.ca
                  • d19dotcaD Offline
                    d19dotcaD Offline
                    d19dotca
                    #29
                    I can confirm too in a recent test if I opt to use the s3-compatible method, and put in the https://storage.bhs.cloud.ovh.net/ endpoint, my backups succeed, and that also jives with what I wrote too last year. So I still wonder if the issue truly is with the storage endpoint. Or is that explained by the path style differences you spoke about earlier? I'm not familiar with that part at all, so not sure if that explains why it works fine when using the s3-compatible method instead of the dedicated OVH Object Storage method for the storage endpoint URL. That page you linked to definitely shows the s3 endpoint URL, but knowing OVH their docs tend to be outdated / not actively maintained, so I wonder if it should still show storage endpoint at all, since that's the endpoint URL shown in the GUI everywhere in the OVH Control Panel and the OopenStack backend. Just throwing it out there. I think you have a better handle on this now than I do, so I'll leave it to you. haha. But if I can help troubleshoot at all further, I'll be happy to help. For now, I've moved to the s3-compatible one and used the s3 endpoint as you suggested.
                    Dustin Dauncey
                    www.d19.ca
                      #30
                      @d19dotca said in Issue with backups listings and saving backup config in 6.2:
                      I can explain at a high level. But essentially, given an endpoint say s3.objectstorage.com, it's a question of how to access the objects of a bucket foo. There are two "styles" of accessing the S3 REST API: one is https://foo.s3.objectstorage.com (the vhost style) and another is https://s3.objectstorage.com/foo (path style). The former as you can see requires a subdomain to be setup per bucket. The latter is deprecated for various reasons including security.
                      When you choose 'OVH', we set the path style to false. When you choose 'S3 compat', we set the path style to true. This is why storage works with S3 compat - it's only supporting a legacy API style.
                      I think OVH does not display s3 in the UI because those are openstack endpoints. In fact, to get S3 API access (as you know) in OVH is super geeky. You have to download this openrc.sh and then use a CLI tool to generate access keys etc. It's really second class citizen / after thought. (S3 API is actually just an optional addon in openstack. Lots of people implemented openstack 5-6 years ago but they are all in various states of dead afaik. only huge/massive companies use it now since it's a behemoth).
                      I pushed a 6.2.1. You can update to that and use the OVH backend which will use s3 subdomain.
                      In any case, if you opened a ticket with OVH, let me know what they say.
                        d19dotcaD Offline
                        d19dotcaD Offline
                        d19dotca
                        @girish Ah that helps explain it then, thanks Girish! 🙂 I really appreciate the time and educational aspect to this. Thanks again!
                        Dustin Dauncey
                        www.d19.ca
                          #32
                          @d19dotca To add to this, this is why minio has path style to true. Because it will be a pain for selfhosters to create a subdomain (dns and certs) for every bucket they create.
                          Edit: just looked this up now. In minio, one can set MINIO_DOMAIN to enable vhost style per https://docs.min.io/docs/minio-server-configuration-guide.html . I have to test if this works with Cloudron's domain alias feature.
