  3. Castopod Host - open-source hosting platform made for podcasters who want engage and interact with their audience.
activitypubfediversepodcast
47 Posts 14 Posters 23.5k Views 16 Watching
  • murgeroM murgero
    @privsec Once you are done uploading make sure the permissions are www-data:www-data with 755.
    P
    P
    privsec
    @murgero I have looked through the docs, but cant find the answer.
    Within the console view of the app, how do I grant those permissions?
    Sorry I am asking really dumb questions.
    • P privsec
      @privsec use the File Manager app instead of console to make it much easier and obvious.
      • P
        P
        privsec
        So I copied the files from the download I got from here
        https://code.castopod.org/adaures/castopod/uploads/d10a3e7cc8c5d8ff57b5d76dcdfeaa58/castopod-1.0.0-beta.20.zip
        into the app/data/ folder. This is what it looks like 55fa0886-47da-4a4f-9e71-b03859b58860-image.png
        I confirmed all files are assigned www-data owner
        I then went to my.domain.com/cp-install and I get c8ca76b9-6b08-4789-a8f6-3fb502278c85-image.png
        I know that I must be missing something simple, but I dont see what.
        murgeroM 1 Reply Last reply
        • P privsec
          murgeroM
          murgeroM
          murgero
          @privsec Can you use CLI to run the following command in /app/data/ and /app/data/public/?
          Run ls -lah <folder> and report back?
          https://urgero.org
          P 2 Replies Last reply
          • murgeroM murgero
            P
            P
            privsec
            @murgero absolutely!
            • murgeroM murgero
              P
              P
              privsec
              wrote on last edited by privsec
              #26
              @murgero said in Castopod Host - open-source hosting platform made for podcasters who want engage and interact with their audience.:
              ls -lah <folder>
              This is the public folder
              This is the app/data folder
              • P privsec
                ls -lah <folder>
                P
                P
                privsec
                I know reuploaded the public folder and corrected the permissions to be www-data.
                I am not back to the Whoops page, it displays Whoops in the tab of the webpage, and only presents a blank white screen in the tab itself.
                When I travel to the /cp-admin url, it presents a login screen, I then login with the credentials of my cloudron account and it acts as if it logs in, but takes me to a blank white page and the URL is cp-auth/login
                I am grateful for your help.
                • P privsec
                  murgeroM
                  murgeroM
                  murgero
                  @privsec
                  1. Castopod has no integration with cloudron, don't do that.
                  2. your permissions on the public folder are bad, gotta fix those. (chown -R www-data:www-data /app/data/public)
                  3. you need to run the install script, which will ask you to setup a new user and password. Use that to login.
                  https://urgero.org
                  • murgeroM murgero
                    @privsec
                    P
                    P
                    privsec
                    @murgero HUZZAH!
                    I can now access the admin dashboard, thank you!
                    • P privsec
                      @steinhmor
                      How did you do it?
                      steinhmorS
                      steinhmorS
                      steinhmor
                      wrote on last edited by steinhmor
                      #30
                      @privsec Sorry for the late reaction.
                      I just changed some settings in app/data/apache/app.conf
                      <VirtualHost *:80>
                      DocumentRoot /app/data/public/castopod/public
                      I also added these lines at the end of the app.conf:
                      php_value post_max_size 200M
                      php_value upload_max_filesize 200M
                      php_value memory_limit 128M
                      I think I found the hint in the cloudron docs for lamp and the castopod docs.
                      Happy to read that you found another solution.
                      Edit: specified the filename.
                      • steinhmorS steinhmor
                        <VirtualHost *:80>
                        P
                        P
                        privsec
                        @steinhmor
                        Those lines you added, is that in the php file?
                        steinhmorS 1 Reply Last reply
                        • P privsec
                          @steinhmor
                          steinhmorS
                          steinhmorS
                          steinhmor
                          @privsec no, these are also part of the Apache-config and tell cloudron / lamp how big the uploaded files are allowed be.
                          • steinhmorS
                            steinhmorS
                            steinhmor
                            I rediscovered the post about changing the Document-root in the cloudron forum:
                            https://forum.cloudron.io/topic/3503/changing-documentroot
                            • jdaviescoatesJ
                              #34
                              1.0 came out recently
                              https://blog.castopod.org/castopod-v1/
                              and there is an official docker
                              https://docs.castopod.org/getting-started/docker.html
                              • whitespaceW
                                whitespaceW
                                whitespace
                                Now that Castopod has reached v 1.0 can we have it on Cloudron? That would be excellent. I wish I could help but I am not a programmer.
                                Alternatively, people who installed Castopod on LAMP-stack, is anyone willing to write a short tutorial?
                                • whitespaceW whitespace
                                  #36
                                  @whitespace said in Castopod Host - open-source hosting platform made for podcasters who want engage and interact with their audience.:
                                  We don't really have any podcasting solutions on Cloudron yet, so it'd be really great to have this!
                                  And extra bonus points because it's also support ActivityPub and so is part of the fediverse too! (which is massively gaining traction because Musk is such an idiot)
                                  micmcM 1 Reply Last reply
                                    micmcM
                                    micmcM
                                    micmc
                                    @jdaviescoates said in Castopod Host - open-source hosting platform made for podcasters who want engage and interact with their audience.:
                                    Moreoever, it already has its Official DOCKER image, so what else is there to ask, or need. 🙂
                                    (coming soon...)
                                    • yusfY
                                      yusfY
                                      yusf
                                      Castopod works great so far on the Cloudron LAMP stack app. Great software.
                                      Only thing not working for me is email smtp.
                                      • yusfY
                                        yusfY
                                        yusf
                                        Can’t get Castopod to federate either, not sure what’s wrong.
                                        scookeS 1 Reply Last reply
                                        • yusfY yusf
                                          scookeS
                                          scookeS
                                          scooke
                                          @yusf Whats the handle(s), I can take a look from outside.
                                          yusfY 1 Reply Last reply
