  3. Backup "Schedule and Retention" not applied? (CIFS Mount)
backupscleanup-backups
12 Posts 4 Posters 4.7k Views 4 Watching
  • P Offline
    P Offline
    p44
    Old backups are not deleted based on retention policy. It seems this affects after last 7.0 update.
    This is a backup on Hetzner storage box as CIFS Mount
    Above you can see folders in storage box.
    Above you can see "Schedule and Retention"
    I noticed this because last backup showed an error due to the disk full.
    Is anyone else having the same problem?
    Thank's
    • P p44
      Thank's
      @p44 from the docs https://docs.cloudron.io/backups/#retention-policy :
      The following are some of the important rules used to determine if a backup should be retained:
      • For installed apps and box backups, the latest backup is always retained regardless of the policy. This ensures that even if all the backups are outside of the retention policy, there is still atleast one backup preserved. This change also ensure that the latest backup of stopped apps is preserved when not referenced by any box backup.
      • An App backup that was created right before an app updates is also marked as special and persisted for 3 weeks. The rationale is that sometimes while the app itself is working fine, some errors/bugs only get noticed after a couple of weeks.
      • For uninstalled apps, the latest backup is removed as per the policy.
      • If the latest backup is already part of the policy, it is not counted twice.
      • Errored and partial backups are removed immediately.
        P Offline
        P Offline
        p44
        @jdaviescoates Thank's for remembering Cloudron retention policy but I think something is not working.
        This is now, FTP folders VS Cloudron info's:
        M 1 Reply Last reply
        • P p44
          M Offline
          M Offline
          msbt
          wrote on last edited by msbt
          @p44 cwd into the folders and check if all of them are complete backups, there are probably app backups from updates in those folders, they aren't listed in the backups view, only when you open each apps settings.
            To extend what @msbt said, if you see only a single app_xx named file inside, it's only an app backup and not a full backup. A full backup will contain all your apps and in addition two files named box_yy and mail_zz.
            • M msbt
              P Offline
              P Offline
              p44
              @msbt @girish I checked inside each folders and they have only one "mail" backup, not the app backup.
              Does this mean that the backup was not successful, although it did not have any errors?
              Schermata 2021-11-16 alle 20.46.46.png Schermata 2021-11-16 alle 20.46.40.png Schermata 2021-11-16 alle 20.46.34.png
              • P p44
                @p44 This seems similar to the bug reported by @d19dotca in https://forum.cloudron.io/topic/5936/questions-on-ovh-object-storage-with-segments-openstack-bucket-container . Looks like maybe mail backups are not getting cleaned up properly for some reason. Let me investigate.
                  There was indeed a bug cleaning up mail backups. This is fixed in coming release. Should be out tomorrow.
                    P Offline
                    P Offline
                    p44
                    @girish Thank's a lot Girish, but it seems that the folders contain only mail backups and not app backups, even if system considered "done" – but not showed – backup.
                    • P p44
                      P Offline
                      P Offline
                      p44
                      wrote on last edited by p44
                      @girish There is something not working with backup system. Old backups they are not deleted and disc fills up.
                      Listed backups on FTP now:
                      Listed backups on Cloudron:
                      I hope this is sufficient enough to initiate a more detailed investigation.
                      Edit: Some folders contains only mail folders and not all app files, even if backup is considered as DONE
                      Edit2: I think problem is solved with latest version 7.0.4
                      • P p44
                        @p44 yes correct, this is what I fixed in 7.0.4
                          P Offline
                          P Offline
                          p44
                          @girish Thank's a lot 👏👏
