  3. Object Storage or Block Storage for backups of growing 60+ GB?
61 Posts 10 Posters 35.7k Views 10 Watching
  • d19dotcaD d19dotca
    @MooCloud_Matt Would you suggest Backblaze over Wasabi in that case? Backblaze charges on command types too so I assumed I’d be better with Wasabi but point taken as their 3-month lifespan requirement struck me as very strange. Went with Wasabi still as it seemed unlikely I’d hit the 1TB limit even with deleted files, plus it has a Canadian Datacentre which will be more performant latency-wise then Backblaze’s California Datacentre when my VPS is hosted in Toronto, Canada.
    MooCloud_MattM
    MooCloud_MattM
    MooCloud_Matt
    @d19dotca
    You must understand what is more valuable for you: speed, reliability, or price.
    reliability mostly Backblaze’s services are one of the best.
    Speed, Wasabi is good enough if is near to your data center, but the is no duplication of data, and is something that we have to use more than want I like to admit.
    Matteo. R.
    Founder and Tech-Support Manager.
    MooCloud MSP
    Swiss Managed Service Provider
    L 1 Reply Last reply
    • L LoudLemur
      @d19dotca said in Object Storage or Block Storage for backups of growing 60+ GB?:
      @LoudLemur Yeah I used Vultr for a little bit when testing but their Datacentre location for their object storage was far away from my VPS Datacentre in Vultr, and it's not too cheap at least compared to what sort of storage you get with Wasabi or Backblaze for example. Not too bad though, for sure, and worth consideration for some.
      d19dotcaD
      d19dotcaD
      d19dotca
      #22
      @LoudLemur & @MooCloud_Matt
      Interesting. I decided to test something with a local Datacentre closer to my VPS called IDrive e2 (seems like a recent s3 competitor from mid-2022 which promises high speeds).
      Backblaze is good although I find it quite slow (mostly because my VPS is in a very far away Datacentre from Backblaze's California (us-west) location. Speed isn't critical since it's just backups but definitely helps still.
      Backblaze's pricing for their API calls scares me a little bit, makes me think it'll be much more pricey than I'm anticipating. May just need to test it out for a while to verify.
      I see what you mean about Wasabi's weird 90-day storage policy which means even deleted files are still counted for 90 days, and my current estimate is quickly adding up, so I think despite initially happy with Wasabi's performance I may need to abandon that provider.
      Still experimenting. Currently in the middle of a large 60+GB backup to IDrive e2 (using rsync instead of tarball for now) and have to say I'm super impressed with the speeds. Their pricing is also quite minimal. Will see if they end up being the one I use.
      Dustin Dauncey
      www.d19.ca
      marcusquinnM L 2 Replies Last reply
      • MooCloud_MattM MooCloud_Matt
        @d19dotca
        @MooCloud_Matt said in Object Storage or Block Storage for backups of growing 60+ GB?:
        @d19dotca
        And price? Which one?
        MooCloud_MattM 1 Reply Last reply
        • L LoudLemur
          @d19dotca
          MooCloud_MattM
          MooCloud_MattM
          MooCloud_Matt
          @LoudLemur probably contabo, they use ceph.
          This means that u have replication by default and a really good support for S3.
          Matteo. R.
          MooCloud MSP
          • d19dotcaD
            d19dotcaD
            d19dotca
            FWIW, I’m quite impressed with the pricing and performance of the newer IDrive e2 storage (with s3 API).
            Curious though on a related but different topic… when uploading to s3, do you find yourself using rsync for larger backups or do you opt to just use tgz? I so far tend to find rsync a bit more performant (likely because of the concurrency settings) but the downside is it takes forever to delete files out of the bucket when there’s so many of them, the deletion process even with s3 API calls is incredibly slow when so many files exist. Makes me think it may be better to just stick to tarball images instead.
            Dustin Dauncey
            www.d19.ca
            doodlemania2D 1 Reply Last reply
              doodlemania2D
              doodlemania2D
              doodlemania2
              wrote on last edited by doodlemania2
              #26
              @d19dotca do you know much about these idrive folks / would you recommend? the pricing almost makes them look like a scam - 2TB of storage for $8/year unlimited egress? i mean, they LOOK legit, but wow that's a helluva deal.
              d19dotcaD 1 Reply Last reply
              • doodlemania2D doodlemania2
                d19dotcaD
                d19dotcaD
                d19dotca
                #27
                @doodlemania2 IDrive has been around for many years for the computer backup solution (competitors to Backblaze and Carbonate for example). This year they released their s3 storage competitor, so they're basically following in the same shoes as Backblaze. It's all legitimate. They're newer so they're trying to sweeten the deal to attract people away from Backblaze and such, hence the lower pricing if you buy their promo for the year plan. It's only that price for the first year though, definitely not a scam IMO.
                I'm currently just trialling with their monthly plan as it's only $0.004 USD per GB, so to store even 800 GB of backups in a month would only be $3.20 USD.
                Dustin Dauncey
                www.d19.ca
                doodlemania2D scookeS 2 Replies Last reply
                  doodlemania2D
                  doodlemania2D
                  doodlemania2
                  @d19dotca I keep thinking that between these newcomers with their free egress and cloudflare shaming them, that Azure and AWS et al will drop the egress fees (or at least lower them)!
                    @doodlemania2 Egress fees? If you want to take your data away, you have to pay?
                      scookeS
                      scookeS
                      scooke
                      @d19dotca You might not believe it, but my idrive account goes back to 2009!
                      • scookeS scooke
                        doodlemania2D
                        doodlemania2D
                        doodlemania2
                        #31
                        @scooke funny story - i just migrated all my stuff to idrive for my mastodon instance only to discover - twoops - they don't appear to allow public buckets!?
                        scookeS robiR 2 Replies Last reply
                          scookeS
                          scookeS
                          scooke
                          @doodlemania2 I also signed up (the regular idrive.com account didn't work with the newer idrive e2), activated S3, made a bucket, checked out the user info, and then saw the buckets were private (for now). Bad timing, hey!
                            @doodlemania2 I think that's a setting before you create the bucket.
                            scookeS 1 Reply Last reply
                              scookeS
                              scookeS
                              scooke
                              @robi Unfortunately it is so. Not sure when they will enable the setting.
                              doodlemania2D robiR 3 Replies Last reply
                              • scookeS scooke
                                doodlemania2D
                                doodlemania2D
                                doodlemania2
                                @scooke anyone know a contact? Would like to stay with them but no public buckets...lol - maybe they can bit flip it for me?
                                  doodlemania2D
                                  doodlemania2D
                                  doodlemania2
                                  went with their main tech support email 🙂
                                  • scookeS scooke
                                    @scooke all regions?
                                    • d19dotcaD
                                      d19dotcaD
                                      d19dotca
                                      #38
                                      Noticing that tgz of about 35-40 GB GB (well that’s the size after compression, it’s really compressing closer to 60+ GB uncompressed data) and it’s nearly double what it consumes in storage because at least the first backup has that snapshot directory too which is a duplicate of the latest backup. My IDrive e2 bucket shows a total usage of 70 GB currently after one system backup.
                                      I notice if I use rsync the backup times are anywheres between about 20-70 minutes, however when using tgz it’s closer to 120 minutes. That’s about the same performance when using Wasabi and even better than Backblaze in my tests so far.
                                      The downside to rsync is it takes forever to delete so many (tens of thousands of) different files from s3 storage, which means Cloudron cleaning it up or even just me doing it manually to purge older data is a real time sink. Makes me want to use tarballs instead however the upload rate seems to be much less performant. I suppose it is maybe a moot point to some degree because it’d normally be done in the middle of the night when time isn’t really a factor, although it will mess things up for two hours during Cloudron version updates if I (which I would) do system backup prior to that task as the maintenance would be so much longer.
                                      I’m curious though… is there a way to improve the tarball performance? Why is it so dang slow? I assume concurrency but what prevents concurrency from taking place when using tarball? @staff, any suggestions here? Anything I can do or any specific recommendations?
                                      I should note I’ve seen next to zero improvements or changes at all whether I use a part size of 128 MB or 1 GB, doesn’t seem to change anything performance wise.
                                      Dustin Dauncey
                                      www.d19.ca
                                        One idea might be to measure just uploading via other tools to see how much the performance difference is. While the tgz code uploader is slow, it's not substantially slower than native tools (from what I have tested). Try to do a tar cvf - upload of the same data directory as the app to the backup storage and measure.
                                          scookeS
                                          scookeS
                                          scooke
                                          @robi I checked most (all non-US ones, 4 US ones) and the Public radio button stayed greyed out.
