  3. dolibarr - ERP & CRM for Business
44 Posts 10 Posters 22.4k Views 11 Watching
  • E erics
    New question : does ".lock" files could be excluded from backups ?
    when dolibarr install is complete a install.lock file is created, but when cloudron backup is restaured this file is missing ...
    E
    E
    erics
    ok, i switched from install.lock to .dbsetup file like wordpress and hoooraaa it works πŸ™‚
    new problem during autotest: database error on test2 + restoring data ... next step tomorrow !
    E 1 Reply Last reply
    • E erics
      E
      E
      erics
      00:41 $ USERNAME=cloudronusername PASSWORD=cloudronpassword node_modules/.bin/mocha --bail test.js
        Application life cycle test
          - build app
          installation and configuration
      App is being installed.
       => Queued
       => Cleaning up old install
       => Downloading image ..........
       => Creating container .
       => Wait for health check .........................................
      App is installed.
            βœ“ install app (61950ms)
            βœ“ can get app information (475ms)
            βœ“ can view welcome page (812ms)
            βœ“ can login (2045ms)
       => Queued
       => Snapshotting app test.example.com
       => Uploading app snapshot test.example.com
       => Uploading backup 1M@1MBps (test.example.com)
      App is backed up
            βœ“ backup app (5252ms)
       => Waiting for app to be uninstalled
       => Queued
       => Deleting container
       => Teardown addons ...
       => Unregistering domains
      App test.example.com successfully uninstalled.
       => Queued
       => Creating container ..
       => Wait for health check ............................................................
      App is installed.
       => Queued
       => Registering subdomains
       => Download backup and restoring addons ........
       => Downloading 1M@1MBps ...................
       => Waiting for DNS propagation
      App is restored
            βœ“ restore app (131164ms)
       => Queued
       => Cleaning up old install .
       => Registering subdomains .
      App configured
            βœ“ move to different location (10705ms)
            βœ“ can access dashboard (508ms)
       => Queued
       => Teardown addons ........
       => Deleting image
      App test2.example.com successfully uninstalled.
            βœ“ uninstall app (15220ms)
          update
      Failed to get app info from store: 404 message: No such app
            1) can install app
        9 passing (4m)
        1 pending
        1 failing
        1) Application life cycle test
             update
               can install app:
           Error: Command failed: cloudron install --appstore-id org.dolibarr.cloudronapp --location test
            at checkExecSyncError (child_process.js:630:11)
            at execSync (child_process.js:666:15)
            at Context.<anonymous> (test.js:195:13)
            at processImmediate (internal/timers.js:456:21)
        #23
        @erics Great progress so far! I guess we need to publish the app to the appstore for the update test to work. Let me do that right now.
        BTW, just a quick note: If there is some upgrade script that needs to be run, we have to do it in the else clause of https://git.cloudron.io/cloudron/dolibarr-app/-/blob/master/start.sh#L14 . Or does dolibarr automatically update/run new db migrations on first run of new version?
          @erics It's published as unstable now. You can try the update test now.
          E 2 Replies Last reply
            E
            E
            erics
            wrote on last edited by erics
            #25
            @girish excellent, i will continue a bit later.
            just a note about git (https://git.cloudron.io/cloudron/dolibarr-app) : i don't have write access so i made a merge request wich is "Ready to be merged automatically. Ask someone with write access to this repository to merge this request "
              E
              E
              erics
              @girish that's pleasant :
              00:45 $ USERNAME=cloudronusername PASSWORD=cloudronpassword node_modules/.bin/mocha --bail test.js
              - build app
              => Queued
              => Downloading image ........................
              App is installed.
              βœ“ install app (74925ms)
              βœ“ can get app information (566ms)
              βœ“ can view welcome page (860ms)
              βœ“ can login (2159ms)
              => Queued
              App is backed up
              βœ“ backup app (4109ms)
              => Queued
              => Deleting image
              => Queued
              => Configuring reverse proxy
              App is installed.
              => Queued
              App is restored
              βœ“ restore app (92784ms)
              => Queued
              App configured
              βœ“ move to different location (9759ms)
              βœ“ can access dashboard (477ms)
              => Queued
              βœ“ uninstall app (8769ms)
              update
              => Queued
              => Downloading icon
              App is installed.
              βœ“ can install app (11025ms)
              βœ“ can get app information (564ms)
              βœ“ can view welcome page (308ms)
              => Queued
              => Deleting container ..........
              βœ“ uninstall app (22671ms)
              13 passing (4m)
              1 pending
              • luckowL
                luckowL
                luckow
                Thank you for the packaging of dolibarr.
                My first 2 cents: let us define, that first language has to be english. It took me around 5 minutes to find out where I can switch from french to english πŸ™‚
                • E erics
                  @erics said in dolibarr - ERP & CRM for Business:
                  Can you please check now? I made you a maintainer of the project.
                  • luckowL luckow
                    @luckow said in dolibarr - ERP & CRM for Business:
                    Ha ha, yes, please πŸ™‚ Would be great if the tests also look for english strings so @nebulon and I can easily continue to maintain it.
                    I did give dolibarr a quick run yesterday, I am looking forward to using it for Cloudron the company as well.
                      E
                      E
                      erics
                      Ok i will have a look for language.
                      i was imagine by default that it was auto detect from browser locale ...
                      Thanks for this first "bug report" i mean πŸ™‚
                        E
                        E
                        erics
                        #31
                        @girish @luckow done πŸ™‚ install is now multilang and based on browser-locale ! please wait for one or two min i will push that code on git ! (thanks @girish now i can write on main git repo).
                        • scookeS
                          scookeS
                          scooke
                          Amazing! You are all simply amazing!
                            #33
                            @erics I made a new build and published a new version. BTW, if dolibarr sends emails, we need to configure email somewhere using the CLOUDRON_MAIL_* env vars
                              E
                              E
                              erics
                              @girish yes that's my next step πŸ™‚
                                E
                                E
                                erics
                                • E erics
                                  E
                                  E
                                  erics
                                  Ok, a new checkbox is checked πŸ™‚
                                  mail configuration
                                  • E erics
                                    mail configuration
                                    marcusquinnM
                                    marcusquinnM
                                    @erics Hey - nice work on this! I've just been exploring and it's come on a long way since the last time I look - congratulations on a solid app that I think will be an asset to Cloudron users as a mature ERP option. ⭐
                                      @erics Is the app ready as such or do you have any pending tasks? We can take it from here, if that's the case.
                                        wrote on last edited by robi
                                        #39
                                        Is LDAP supposed to be working?
                                        I can't log in via Cloudron user credentials w/o creating a separate account in Dolibarr.
                                          BrutalBirdieB
                                          BrutalBirdieB
                                          @robi => @luckow wrote
                                          What is the reason to login as an admin, select ldap users from a dropdown and add them to the userbase in dolibarr? Without that workflow it isn't possible to login as an allowed user (from the cloudron app/dashboard perspective).
                                          Tested with a fresh installation.
                                          https://forum.cloudron.io/topic/3474/unusual-ldap-user-workflow?_=1604397103462
