  2. Package development
  3. Translations for Cloudron
36 Posts 14 Posters 22.6k Views 12 Watching
    @ei8fdb I installed the poll plugin on this forum for you if you want to give it a try (make a separate post somwhere). This is the plugin I installed - https://github.com/NodeBB/nodebb-plugin-poll . There is a button in the new post dialog (looks like a graph), if you click it, it brings up a poll window.
    ei8fdbE
    ei8fdbE
    ei8fdb
    wrote on last edited by ei8fdb
    #21
    @girish Thanks for doing that. I did try it - the only issue is the poll doesn't have an option for the participant to an other option, and so all languages would need to be listed from the beginning.
    (I've changed the link abive to link directly to the survey)
    • ei8fdbE
      ei8fdbE
      ei8fdb
      #22
      Results so far:
      Responses to the question "What is the main language you speak?"
      If you'd like to contribute your answer, you can fill out the 2 question survey.
      ei8fdbE 2 Replies Last reply
      • ei8fdbE ei8fdb
        Results so far:
        ei8fdbE
        ei8fdbE
        ei8fdb
        @girish @nebulon These are the results so far. There's been no new data since the Nov 19th.
        I'll leave the survey open in case more people reply.
        Hope that's useful!
        • ei8fdbE ei8fdb
          Hope that's useful!
          @ei8fdb thanks that is useful. We will ship Cloudron 6 with only English and German as fully translated. This is only because those are the languages we at Cloudron speak πŸ˜‰
          However once version 6 is out, it supports downloading new languages and translations without update, so essentially once a Cloudron is then updated to version 6 then everyone can help out with translation for the rest πŸ™‚
          imc67I ei8fdbE 3 Replies Last reply
            imc67I
            imc67I
            imc67
            translator Super Fan
            @nebulon can we already start with translating as it might take some time? (Dutch/nl)
            • luckowL
              luckowL
              luckow
              To give an idea: the whole translation is done while playing a 10 episode netflix series. After this process you need 3 times 2 hours to make the translation consistent and correct your own typos.
              If you want to translate in a team, start with guidelines.For German we have decided to translate according to these guidelines:
              • be inclusive & friendly
              • avoid to gender. try to find better terms
              • if gender is needed use the "*" format
              • only translate widly used tech terms. if there is no, don't translate
              • in the german language we make a difference between formal and informal salutation. Try to avoid direct salutation.
              • put often used terms in the glossary
              • as long as necessary but short in focus
              ei8fdbE 1 Reply Last reply
                ei8fdbE
                ei8fdbE
                ei8fdb
                @nebulon Glad it's useful.
                Yup that makes sense.
                Great, and the translations will be managed on weblate? I'd like to help with Spanish localisation.
                • luckowL luckow
                  ei8fdbE
                  ei8fdbE
                  ei8fdb
                  Thanks @luckow πŸ‘ these are good recommendations and advice about the process, particularly:
                  • avoid to gender. try to find better terms. if gender is needed use the "*" format
                  I am not familar with * format?
                  ☝ This does bring up a question: what tone does Cloudron.io want Cloudron to have? Serious? Scary? Helpful? Friendly? πŸ™‚
                  ☝ this can be hard πŸ™‚
                  Doing localisation so everybody can understand is a whole expertise in itself - I am not an expert, but I do try to contribute from the users perspective, and it's important to remember that not all Cloudron users are technology professionals! πŸ™‚
                  It is also important to mention - in some languages there are no words for concepts like security/privacy/encryption - these are not cultural concepts. For the first first languages, this probably won't be a big issue.
                  Here is a set of glossaries created by Localisation Lab, a great organisation who do localisation work for a lot of open source projects and "technical" projects with their community of native speakers.
                  https://www.localizationlab.org/glossaries
                  It has glossaries for many "technical" terms in many languages, for example in Spanish:
                  attachment - adjunto
                  database - base de datos
                  decryption - descifrado
                  default server - Servidor predeterminado
                  Here are the glossaries for:
                  Spanish, French, and Dutch.
                  luckowL 1 Reply Last reply
                  • ei8fdbE ei8fdb
                    luckowL
                    luckowL
                    luckow
                    #29
                    @ei8fdb said in Translations for Cloudron:
                    I give a concrete example. It's possible to translate owner into the german word Besitzer. But in this case a masculine word is choosen. There is also a translation into Besitzerin possible. And Besitzerin is the female version of Besitzer. In our time and in discussions about an inclusive and gender-sensitive understanding, it is good to choose a "format" for how to deal with both versions of the "same" translation.
                    • Besitzer/in
                    • Besitzer & Besitzerinnen
                    • sometimes Besitzer, sometimes Besitzerin
                    • Besitzer*in
                    In that case we chose Besitzerin as the "" format.
                    • luckowL luckow
                      • Besitzer/in
                      • Besitzer*in
                      ei8fdbE
                      ei8fdbE
                      ei8fdb
                      #30
                      @luckow Aha thanks. I studied German for 6 (7?) years in school (Entschuldigung, wie komme ich am bestem zum Bahnhof bitte?!) and university, but I think I missed that lesson. πŸ˜„
                      • V
                        V
                        vjvanjungg
                        just did the survey. where can we begin?
                          ei8fdbE
                          ei8fdbE
                          ei8fdb
                          @vjvanjungg here's what @nebulon said about Translations for Cloudron:
                          Hope that helps.
                          V 1 Reply Last reply
                          • ei8fdbE ei8fdb
                            Hope that helps.
                            V
                            V
                            vjvanjungg
                            @ei8fdb ha.. i missed that 😜thanksβ€”will wait then
                            • ei8fdbE ei8fdb
                              Results so far:
                              ei8fdbE
                              ei8fdbE
                              ei8fdb
                              Results so far:
                              20 responses as of today.
                              girishG ei8fdbE 2 Replies Last reply
                              • ei8fdbE ei8fdb
                                Results so far:
                                #35
                                Who is the second tamilian in this forum πŸ™‚ ? (I am one of them, though I am not of any use with translations since I can only speak and sort of read and hardly write...).
                                • ei8fdbE ei8fdb
                                  Results so far:
                                  ei8fdbE
                                  ei8fdbE
                                  ei8fdb
                                  22 responses as of today:
                                  Language responses
                                  • girishG girish unpinned this topic on
